makkam Inserito: 23 maggio 2009 Segnala Inserito: 23 maggio 2009 sorry i have a problem with the tv toshiba all the team in stby pin 56 in VCT 1.2V please if you have the shema or you can . me thank's
giap72 Inserita: 23 maggio 2009 Segnala Inserita: 23 maggio 2009 (modificato) hi.. welcome to the plcforum site,We are very happy to see that our website is known throughout the world...the electric schematic you can find in this section of the site:Altri argomenti-->up\download filethem looking for Amstrad-Vestel-Roadstar folder.. Attention!! before download the files you must to do another registration..enjoy.. Modificato: 23 maggio 2009 da giap72
Fulvio Persano Inserita: 24 maggio 2009 Segnala Inserita: 24 maggio 2009 Ciao giap72.Compliments for the your english (written)!
makkam Inserita: 26 maggio 2009 Autore Segnala Inserita: 26 maggio 2009 Thank you GIAP 72 . bat wher i can do the ather registration please thank's
makkam Inserita: 26 maggio 2009 Autore Segnala Inserita: 26 maggio 2009 it's ok for the registration bat the model is not same lake toshiba i think the quartz X100 (20.25MHZ)it's the problemeand for you wath do you think.
giap72 Inserita: 27 maggio 2009 Segnala Inserita: 27 maggio 2009 sorry but i have only schema of the chassis vestel 17mb21 Can you explain wich is the problem? Do you made some measure on the switched mode or horizzontal section?
makkam Inserita: 27 maggio 2009 Autore Segnala Inserita: 27 maggio 2009 CIAO GIAP 72ALL THE ALIMANTATION IN STBY MODE IT's OK 1.8V STB /5V STB/3.3V STB IF YOU SEA THE SCHEMA 17MB21-1 VESTEL VCTI PART 1OF5 DATE 18.01.2006 IN HITASH IC 102 PIN54(p17 POWCOM) IF i presse OR NOT the ON SWITCH I have 1.2Vthe TV IS IN STBY MODE .
giap72 Inserita: 28 maggio 2009 Segnala Inserita: 28 maggio 2009 ok,the tension are all right and the ic's is in st.by mode...i think you check the SCL and DATA signal at the pin 58-57 and the quartz waveform's at the pin 25-26..I wait for your reply..good work..
makkam Inserita: 28 maggio 2009 Autore Segnala Inserita: 28 maggio 2009 SALU FOR THE SIGNAL OF THE PIN 58 AND 3.4 V ALSO FOR THE PIN 57 BUT FOR XTAL1 and 2 I HAVE TO VERIFY THE TENSION SHE(IT) AND OF 1.8V; NOT BY MEANS OF OSCILOSCOPEi trySALU Per Il Segnale Di La spilla 58 E Di3.4 V Di Nonna Per La spilla 57 Ma Per XTAL1 E 2 ho Verificare La Tensione Lei E Di1.8V; NON ALL'AIUTO DI OSCILOSCOPE
