Vcr Grundig Vs 710 - F1
Ciao,appena mi hanno portato questo vcr,aveva il carrello caricato senza videocassetta,dopo aver smontato il carrello,l'ho sostituito con un altro ed ora prende la cassetta,ma sul display compare la scritta F1 e si spegne.Aspetto notizie.
Hi-MD_DVD-RAM
Ciao amin,
Ho trovato un manuale serivzio on-line (formato Adobe *.pdf) di Grundig VS710/VS810 in linuga tedesco ed inglese.
Ho letto, questo manuale pagina 11 (finestra Adobe), descrizione display F1 solo per VS810!
Ecco, attenzione solo modello VS810!:
1.2 Display and Display Drive
In principe the display is a directly heated triode valve. The heating element of the valve is also the cathode. To the pins 1 and 2 of the display there is the heating voltage F1 (-20.7V) and on pins 36 and 37 the heating voltage F2 (-17V). The display will light up only if the anode and the appropriate grid is more positive than the cathode. The display drive is accomplished in time-multiplex mode. The scanning clock is approx. 68Hz with a scanning ratio of 1:8. The anode drive of the segments (S1...S16) is carried out via the output ports P30...P33, P50...P53, P80...P83 and P90...P93 of IC1130.
The grid drive (G9...G1) is via the output ports P100...P103, P110...P112, P23 and P113 of IC1130. The required anode and grid current is provided by internal driver stages (High-Voltage-Output) of the IC1130. The operating point of the driver stages is determined by the voltage divider R1108/R1112. IC1130-(4) thus provides a voltage of about -6V.
Example:
"1" (extreme right) is to light up.
The output ports P91 and P92 (anodes) and P23 (grid) must simultaneously be switched to +5V.
If the anodes and grids are not driven, then these are taken to approx. -27VD (la lettera D in basso di Volt è pedice) via internal Pull-down-resistors by the output ports of IC1130.
Non posso allegare un file in questo forum pubblico, preferisco ti manderò solo suo e-mail.
Ciao,scusa se ti rispondo solo ora,ma sono stato fuori.Allora ti mando con un messaggio privato la mia e-mail.Ti ringrazio fin da ora per l'aiuto.Ciao
  • 2 months later...
ANCH' IO AVREI UN DISPERATO BISOGNO DEL MANUALE E DELLO SCHEMA DEL Vcr Grundig Vs 710. TI HO MANDATO UNA MAIL "Hi-MD_DVD-RAM" PER CHIEDERTI SE ME LO PUOI INVIARE PER POSTA. GRAZIE MILLE !
