Philips 28pt405a/00 - Scrive BLOCCAGGIO
Salve, ho un tvc Philips 28PT405A/00 che dopo il trasloco scrive all'accensione "BLOCCAGGIO". Quale potrebbe essere il problema?
Potrebbe essere in "Hotel Mode".
Se così fosse, prova questa procedura:
Hotel mode
Hotel mode Receivers employing the GR2.1 chassis are equipped with a Hotel mode facility.In this mode certain functions are restricted. To engage the hotel mode proceed as follows: First set the volume to the maximum level required when in hotel mode.Then switch to programme 38 and simultaneously press programme - and volume + buttons. The set is now in hotel mode and the following conditions apply: 1) The volume cannot be increased beyond its setting at the time of entry to the mode. 2) The installation mode cannot be accessed. 3) Personal preference values cannot be stored. To leave the hotel mode, switch to programme 38 and once again press simultaneously programme - and volume + buttons.
Oppure in "child look".
How to enable/disable Child Lock
Press MENU button on Remote Control. When the menu appears on the screen, you select SPECIAL FEATURES (this expression is language dependent) Within SPECIAL FEATURES, the CHILD LOCK can be enabled or disabled.
Grazie per la risposta.Lo schermo è tutto nero con la scritta bloccaggio in rosso quindi non riesco ad andare nei canali, proverò con la funzione Child Lock e vi farò sapere.
