mister charlie Inserito: 14 luglio 2012 Segnala Inserito: 14 luglio 2012 TV SONY KV-29LS35E NON ACCENDE RIMANE LED LAMPEGGIARE vorrei sapere dove devo mettere le mani su quale integrato il rele' funziona ,l'interruttore funziona vicino al rele' c'è un integrato che era caldissimo che potevi anche accendere una sigaretta volevo sapere se puo' essere lui la sigla completa è EPCOS T70902023 MI sapete dare indicazioni? perchè anche se è' una televisione analogica a tubo catodico si vede benissimo ! aspetto con ansia la vostra risposta!
Riccardo Ottaviucci Inserita: 15 luglio 2012 Segnala Inserita: 15 luglio 2012 (modificato) quanti lampeggi fa? Sony Blinking Codes Many of the later model Sony TV's have a built in Self- Diagnosis function. If the timer/standby indicator is blinking, this could be an indication of the problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. The timing of the blinking you see would be as follows: two to eight blinks (depending on the fault) about a third of a second apart, then pauses for 3 seconds, then the two to eight blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those which you will see for each of these faults on a diagnosis screen described later in this article. Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open) Continuous Blink Once A Second, No Pausing As Discussed Above--- No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective. ONE Blink--- not used for the self-diagnosis TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505 FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly. SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402. Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons: Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes. So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure, but it's a little better than a poke in the eye with a sharp stick. IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns everything to the factory preset condition. oppure per il telaio FE2 No error 00 Reserved 01 OCP ( Over Current Protection ) 02 Not Used 03 No Vertical Sync 04 IKR Error at power on 05 IIC bus clock and/or data lines low at power on 06 NVM no IIC bus acknowledge at power on 07 Not Used 08 Tuner no acknowledge at power on 09 Sound Processor Error 10 Jungle controller 8 volts error 11 Modificato: 15 luglio 2012 da Riccardo Ottaviucci
marpel Inserita: 29 agosto 2012 Segnala Inserita: 29 agosto 2012 salve a tutti, mi unisco al problema. ho un sony kv29ls35e telaio fe2 e il led lampeggia 11 volte, quindi secondo la diagnostica sony controller 8 volt error.... da premettere che in alcuni casi il televisore in questione accende perfettamente. il problema e' la partenza. comunque andiamo al problema pensavo a qualche condensatore sul primario... forse qualcuno ha gia' risolto e puoi darci qualche tips...
mistertv Inserita: 12 novembre 2020 Segnala Inserita: 12 novembre 2020 Bè, vista l'età delle discussioni penso che i tv siano già in discarica jank7, discussioni cosi vecchie inutile tenerle aperte.
