Problemi Con Modem-router Atlantis
salve wallbash.gif io ho alice tutto incluso ed ho sostituito il modem-router con un'atlantis webshare 141w wireless adsl2+ router, ho collegato il tutto, acceso ma non mi da nessuna connessione e non so come configurarlo, i parametri da configurare sono moltissimi e facendo qualche giro in internet ho solo due o tre parametri,una goccia nell'oceano,ho provato con quei pochi ma senza alcun risultato, senzasperanza.gif POTRESTE AIUTARMI, vi ringrazio anticipatamente worthy.gif
schermata internet
ATM VC
Virtual Circuit : PVC0PVC1PVC2PVC3PVC4PVC5PVC6PVC7
Status : Activated Deactivated
VPI : (range: 0~255)
VCI : (range: 1~65535)
QoS
ATM QoS : CBRUBRrtVBRnrtVBR
PCR : cells/second
SCR : cells/second
MBS : cells
Encapsulation
ISP
: Dynamic IP Address
Static IP Address
PPPoE/PPPoA
Bridge Mode
PPPoE/PPPoA
Username :
Password :
Encapsulation : PPPoE LLCPPPoE VC-MuxPPPoA LLCPPPoA VC-Mux
Half Bridge : Activated Deactivated
Connection Setting
Connection : Always On (Recommended)
Connect On-Demand (Close if idle for minutes)
Connect Manually
TCP MSS Option : TCP MSS(0 means use default) bytes
IP Address
Get IP Address : Static Dynamic
Static IP Address :
IP Subnet Mask :
Gateway :
NAT : DisabledEnable
Default Route : Yes No
TCP MTU Option : TCP MTU(0 means use default) bytes
Dynamic Route : RIP1RIP2-BRIP2-M Direction NoneBothIN OnlyOUT Only
Multicast : DisabledIGMP v1IGMP v2
shermata lan
Router Local IP
IP Address :
IP Subnet Mask :
IGMP Snoop : Disabled Enabled
DHCP
DHCP : Disabled Enabled Relay
DHCP Server
Starting IP Address :
IP Pool Count :
Lease Time : seconds (0 sets to default value of 259200)
DNS
DNS Relay : Use Auto Discovered DNS Server OnlyUse User Discovered DNS Server Only
Primary DNS Server :
Secondary DNS Server :
schermata wireless
Access Point Settings
Access Point : Activated Deactivated
Channel ID : ITALY AutoChannel062437MHz Current Channel: 6
Beacon Interval : (default 100 msec, range: 20~1000)
RTS/CTS Threshold : (default 2347, range: 1500~2347)
Fragmentation Threshold : (default 2346, range: 256~2346, even numbers only)
DTIM : (default: 1, range: 1~255)
802.11 b/g : 802.11b802.11g802.11b+g
SSID Setting
SSID Index : 1
SSID :
Broadcast SSID : Yes No
Authentication Type : DisabledWEP-64BitsWEP-128BitsWPA-PSKWPA2-PSK
Wireless MAC Address Filter
Active : Activated Deactivated
Action : Allow AssociationDeny Association the follow Wireless LAN station(s) association.
Mac Address #1 :
Mac Address #2 :
Mac Address #3 :
Mac Address #4 :
Mac Address #5 :
Mac Address #6 :
Mac Address #7 :
Mac Address #8 :
