Evento Calculate
Vorrei far si che mi parta automaticamente (anzi che manualmente) una macro al cambiamento automatico di orario in tre celle dove le ore vengono messe li tramite formule
Nel foglio ho inserito questo codice
Private Sub Worksheet_Change(ByVal Target As Range)
If Not Intersect(Range("AX1,AY1,AZ1"), Target) Is Nothing Then
    If Range("AX1") <> "" And Range("AY1") <> "" _
    And Range("AZ1") <> "" Then Call minuti
End If
End Sub
E nel modulo
Sub minuti()
Dim AX As Range
Dim AY As Range
Dim AZ As Range
Dim F As Range
Dim G As Range
Dim H As Range
Set AX = ThisWorkbook.Sheets("GEN ").Range("AX1")
Set AY = ThisWorkbook.Sheets("GEN ").Range("AY1")
Set AZ = ThisWorkbook.Sheets("GEN ").Range("AZ1")
Set F = ThisWorkbook.Sheets("GEN ").Range("F10")
Set G = ThisWorkbook.Sheets("GEN ").Range("G10")
Set H = ThisWorkbook.Sheets("GEN ").Range("H10")
Select Case True
'PRIMO CASO
Case VBA.Minute(AX) > 30 And VBA.Minute(AY) = 0 And VBA.Minute(AZ) = 0
    Application.EnableEvents = False
    F = VBA.Hour(AX) + 1
    G = VBA.Hour(AY)
    H = VBA.Hour(AZ)
Case VBA.Minute(AX) = 0 And VBA.Minute(AY) > 30 And VBA.Minute(AZ) = 0
    F = VBA.Hour(AX)
    G = VBA.Hour(AY) + 1
    H = VBA.Hour(AZ)
Case VBA.Minute(AX) = 0 And VBA.Minute(AY) = 0 And VBA.Minute(AZ) > 30
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
    H = VBA.Hour(AZ) + 1
'SECONDO CASO
Case VBA.Minute(AX) > 0 And VBA.Minute(AY) > 0 And VBA.Minute(AZ) = 0 _
And VBA.Minute(AX) + VBA.Minute(AY) > 30 And VBA.Minute(AX) _
+ VBA.Minute(AY) <= 60
    G = VBA.Hour(AY)
    H = VBA.Hour(AZ)
And VBA.Minute(AX) + VBA.Minute(AY) > 60
    F = VBA.Hour(AX)
    H = VBA.Hour(AZ)
'TERZO CASO
Case VBA.Minute(AX) > 0 And VBA.Minute(AY) = 0 And VBA.Minute(AZ) > 0 _
And VBA.Minute(AX) + VBA.Minute(AZ) > 30 And VBA.Minute(AX) _
+ VBA.Minute(AZ) <= 60
    F = VBA.Hour(AX)
    H = VBA.Hour(AZ)
And VBA.Minute(AX) + VBA.Minute(AZ) > 60
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
'QUARTO CASO
Case VBA.Minute(AX) = 0 And VBA.Minute(AY) > 0 And VBA.Minute(AZ) > 0 _
    And VBA.Minute(AY) + VBA.Minute(AZ) > 30 And VBA.Minute(AY) _
    F = VBA.Hour(AX)
    H = VBA.Hour(AZ)
    And VBA.Minute(AY) + VBA.Minute(AZ) > 60
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
'OTTAVO CASO
Case VBA.Minute(AX) > 0 And VBA.Minute(AY) > 0 And VBA.Minute(AZ) > 0 _
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) > 150
    F = VBA.Hour(AX)
    H = VBA.Hour(AZ) + 2
'SETTIMO CASO
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) > 120 _
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) <= 150
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
'SESTO CASO
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) > 60 _
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) <= 90
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) > 90 _
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) <= 120
    F = VBA.Hour(AX)
'QUINTO CASO
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) > 30 _
And VBA.Minute(AX) + VBA.Minute(AY) + VBA.Minute(AZ) <= 60
    F = VBA.Hour(AX)
    H = VBA.Hour(AZ)
    F = VBA.Hour(AX)
    G = VBA.Hour(AY)
'IN NESSUNA DELLE CONDIZIONI SOPRA
Case Else
    F = ""
    G = ""
    H = ""
End Select
Set AX = Nothing
Set AY = Nothing
Set AZ = Nothing
Set F = Nothing
Set G = Nothing
Set H = Nothing
Application.EnableEvents = True
End Sub
Chi mi aiuta a mettere un evento Calculate?
