Microsoft Web Browser - Come si usa?
Ciao a tutti, ho provato ad inserire Microsoft Web Browser in un Form di Visual Basic ma non mi visualizza niente, qualcuno sa come funziona?
Questo è il codice del form Browser (di nome frmBrowser)
Option Explicit
Public StartingAddress As String
Dim mbDontNavigateNow As Boolean
Private Sub Form_Load()
On Error Resume Next
Me.Show
tbToolBar.Refresh
Form_Resize
cboAddress.Move 50, lblAddress.Top + lblAddress.Height + 15
If Len(StartingAddress) > 0 Then
cboAddress.Text = StartingAddress
cboAddress.AddItem cboAddress.Text
'Tenta di passare all'indirizzo iniziale
timTimer.Enabled = True
brwWebBrowser.Navigate StartingAddress
End If
End Sub
Private Sub brwWebBrowser_DownloadComplete()
Me.Caption = brwWebBrowser.LocationName
End Sub
Private Sub brwWebBrowser_NavigateComplete(ByVal URL As String)
Dim i As Integer
Dim bFound As Boolean
For i = 0 To cboAddress.ListCount - 1
If cboAddress.List(i) = brwWebBrowser.LocationURL Then
bFound = True
Exit For
End If
Next i
mbDontNavigateNow = True
If bFound Then
cboAddress.RemoveItem i
End If
cboAddress.AddItem brwWebBrowser.LocationURL, 0
cboAddress.ListIndex = 0
mbDontNavigateNow = False
End Sub
Private Sub cboAddress_Click()
If mbDontNavigateNow Then Exit Sub
brwWebBrowser.Navigate cboAddress.Text
End Sub
Private Sub cboAddress_KeyPress(KeyAscii As Integer)
If KeyAscii = vbKeyReturn Then
cboAddress_Click
End If
End Sub
Private Sub Form_Resize()
cboAddress.Width = Me.ScaleWidth - 100
brwWebBrowser.Width = Me.ScaleWidth - 100
brwWebBrowser.Height = Me.ScaleHeight - (picAddress.Top + picAddress.Height) - 100
End Sub
Private Sub timTimer_Timer()
If brwWebBrowser.Busy = False Then
timTimer.Enabled = False
Else
Me.Caption = "Operazione in corso..."
End If
End Sub
Private Sub tbToolBar_ButtonClick(ByVal Button As Button)
Select Case Button.Key
Case "Back"
brwWebBrowser.GoBack
Case "Forward"
brwWebBrowser.GoForward
Case "Refresh"
brwWebBrowser.Refresh
Case "Home"
brwWebBrowser.GoHome
Case "Search"
brwWebBrowser.GoSearch
Case "Stop"
brwWebBrowser.Stop
End Select
End Sub
Ti Scrivo anche i componenti usati in questo codice
e Approssimativamente le proprietà di essi
poi se vorrai potrai modificarle da te:
Nome: brwWebBrowser Componente: WebBrowser
Nome: cboAddress Componente: ComboBox
Nome: imlIcons Componente: ImageList Proprieta: Contenga almeno 6 immagini (immagini nella ImageList che saranno le icone dei 6 Pulsanti)
Nome: lblAddress Componente: Label Proprieta: Tag e Caption &Indirizzo:
Nome: picAddress Componente: PictureBox Proprieta: LinkTimeout 50
Nome: timTimer Componente: Timer Proprieta: Interval 5
Nome: tbToolBar Componente: Toolbar Proprieta: Contenga almeno 6 Pulsanti
Pulsanti dentro alla tbToolBar per:
1° indietro 2° Avanti 3° ferma 4° Aggiorna 5° Home 6° Cerca
Questo è il codice che devi mettere dentro ad un pulsante che ti avvia il frmBrowser
(io il Browser lo ho messo come form MDChild dentro un form Main , nel codice è già impostato il resize)
Dim frmB As New frmBrowser
frmB.StartingAddress = "http://astalavista.box.sk/cgi-bin/robot"
frmB.Show
Io ho messo la pagina di ricerca di Astalavista come avvio tu mettu quella che vuoi
Prova e in bocca al lupo ;)
Modificato: da Brothers
Grazie mille, ci lavoro un pò su perche con .net non miaccetta tutti i parametri degli oggetti, appena finito ti faccio sapere come va...
