Sony Kdl32P5600 - Si Spegne E Comincia A Lampeggiare 8 Lampeggi.
La mia televisione sony kdl32p5600 ha improvvisamente smesso di funzionare, l'unica cosa che fa quando provo ad accenderla è: accende il monitor per 2 secondi, dopo si spegne e comincia a lampeggiare, fa 8 lampeggi. Se qualcuno può essermi d'aiuto.
Carlo
spero tu tragga da quanto segue qualche indizio
TV LCD Sony KDL-32P5600
<< < (2/2)
ZamfirTV:
buna ziua va rog daca ma puteti ajuta si pe mine cu aceasta problema .am un tv sony kdl-32s5600 a venit cu invertorul defect .nu am avut timp sa ma ocup de el sa vad ce are asa ca am pus unul bun testat di recuperari.tvul se lumineaza 4secunde apare osdul dupa care ledul palpaie de 4 ori pauza si se repeta la nesfarsit.manualul service da eroare 4 invertor defect dar nu stiu cum sa resetez eroarea din tv, deaceia am apelet la dv poate ati avut aceasta situatie va multumesc. EX2N SELF DIAGNOSTIC SOFTWARE
The identification of errors within the EX2N chassis is triggered in one of two ways :- 1: Busy or 2: Device failure to respond to IIC. In the
event of one of these situations arising the software will first try to release the bus if busy (Failure to do so will report with a continuous flash-
ing LED) and then communicate with each device in turn to establish if a device is faulty. If a device is found to be faulty the relevant device
number will be displayed through the LED (Series of flashes which must be counted).
LED Error Codes and Descriptions
Number of LED
Flashes
Error DescriptionCheckedAction
02Balancer error.In normal and factory mode.Goes into standby.
03Power supply protection error.In normal and factory mode.Goes into standby.
04Inverter error.In normal and factory mode.Goes into standby.
05NVM error.In initialisation state.Adds error to error menu.
06IIC error.In normal and factory mode.Adds error to error menu.
08Audio error.In normal and factory mode.Adds error to error menu.
09Tuner error.In initialisation state.Adds error to error menu.
18COFDM error.In digital mode and initialisation state.Adds error to error menu.
19USB error.In normal and factory mode.Adds error to error menu.
20CI error.In normal and factory mode.Adds error to error menu.
Delete “Error History” in Service Menu
1. Confirm latest software version is fitted.
2. Enter Factory Mode : TT19
3. Set Shipping Condition : TT08
4. Confirm Error History deleted
Scusami ma non ho capito nulla. Non capisco neache che lingua sia la prima.
la lingua non me' la nostra e non la comprendo nemmeno io , ma otto lampeggi sembrano evidenziare una anomalia audio.
tenta di cancellare le anomalie registrate con la procedura indicata nelle ultime quattro righe. di più io non so dirti speriamo
nel conforto di un service-men Sony.
Il problema è che non rimane accesa la tv e quindi non si riesce a cancellare le anomalie
in attesa di consigli da parte di un esperto Sony controlla se ci sono elettrolitici gonfi e se l'IC finale audio risulta esploso o surriscalda durante l'accensione, dovresti individuarlo seguendo il cablaggio a ritroso dagli altoparlanti.
abbiamo aperto e guardato, con un amico che è tecnico panasonic, addirittura ha rifatto tutte le saldatature, ha provato a disconettere la scheda audio ma continua a fare gli otto lampeggi e a non accendersi.
per entrare in service prova :
impostare OFF (spento) poi premere rapidamente DISPLAY 5 VOL + PWR.
Premere 1 o 4 per selezionare la regolazione che si desidera modificare
Premere 3 o 6 per regolare
Premere MUTE quindi Invio per salvare ogni regolazione
Fulvio Persano
La prima è rumeno,mentre la seconda inglese.
La prima parte (in rumeno) non dovrebbe interessarti,visto che è un modello differente e tratta l'errore 4.
Error code 8 = 08 Audio error.In normal and factory mode.Adds error to error menu.
tradotto = 08 Errore audio. In modalità normale e fabbrica. Aggiunge errore al menu di errore.
:thumb_yello:
Suggerimento: al fine di non peggiorare la situazione,portalo presso un CAT Sony.
