Lcd Inno Hit 32 In Standby - 17Pw26-4 V.1
Marco De Bortoli
Questo è il contenuto del SERVICE MENU così come presentato nel Service Manual della 17MB35 ma che di fatto ho riscontrato praticamente identico sul mio tv:
16. SERVICE MENU SETTINGS
In order to reach service menu, First Press “MENU” Then press the remote control
code, which is “4725”. In DTV mode, first press “MENU” and select “TV SETUP”.
Then, press “4725”.
16.1. Video Setup
Panel Info <..................................>
32_LC_SAC1
Blue Background <.....>
If “Menu” selected, “Blue Background” item is seen in “Feature”
menu.
If “Yes” selected, “Blue Background” is on and not seen in
“Feature” menu
Film Mode <.....>
If “Yes” selected, “Film Mode” feature is active.
Dynamic Contrast <.....>
If “Yes” selected, “Dynamic Contrast” feature is active.
Game Mode <...........>
If “Yes” selected, “Game Mode” feature is active
SRGB For PC <...........>
If “Yes” selected, PCs can use SRGB option.
Dynamic Noise Reduction<...........>
If “Yes” selected, “Dynamic Noise Reduction” feature is active
WSS Option<...........>
If “Yes” selected, WSS Option can be used
16.2. AudioSetup
BG<.....>
Europe
New Zelland
Australia
No
DK<.....>
I<.....>
L<.....>
Equalizer <.....>
If “Yes” selected, “Equalizer” item is seen in “Sound” menu.
Headphone <.....>
If “Yes” selected, “Headphone” item is seen in “Sound” menu.
Power On/Off Melody <.....>
If “Yes” selected, when power on/off conditions, the power on/off
melody can be heard.
Dynamic Bass <.....>Value between 0 to 12
Effect<.....> Value between 0 to 7
Audio Delay ,offset <.....> Value between 0 to 190
Audio Setup Cont...2
Carrier mute<.......> Value between 0 to 28
Headphone Sound Select <.......>
Always Active Select
Always Inactive Select
Menu
Always Main Menu
Always PIP/PAP Window
Sound Mode Detect Time <.......> Value between 0 to 255
Noise Reduction Threshold <.......> Value between 0 to 255
Noise Reduction Time <.......> Value between 0 to 15
AVL Attack Time <.......> Value between 0 to 255
AVL Release Time <.......> Value between 0 to 255
Prescales ( AVL On)
FM Prescale<.......> Value between 0 to 255
AM Prescale <.......> Value between 0 to 255
NICAM Prescale <.......> Value between 0 to 255
SCART Prescale <.......> Value between 0 to 255
FAV Prescale <.......> Value between 0 to 255
DTV Prescale <.......> Value between 0 to 255
HDMI Prescale <.......> Value between 0 to 255
YPbPr/PC Prescale <.......> Value between 0 to 255
An. USB Prescale <.......> Value between 0 to 255
Dig. USB Prescale <.......> Value between 0 to 255
Prescales ( AVL Off)
Clipping Levels ( AVL On)
FM Clipping <.......> Value between 0 to 255
AM Clipping <.......> Value between 0 to 255
NICAM Clipping <.......> Value between 0 to 255
SCART Clipping <.......> Value between 0 to 255
FAV Clipping <.......> Value between 0 to 255
DTV Clipping <.......> Value between 0 to 255
HDMI Clipping <.......> Value between 0 to 255
YPbPr/PC Clipping <.......> Value between 0 to 255
An. USB Clipping <.......> Value between 0 to 255
Dig. USB Clipping <.......> Value between 0 to 255
Clipping Levels ( AVL Off)
16.3. Service Scan/Tuning Setup
First Search for L/L’ <.......>
ATS Delay Time (ms) <.......> Value between 0 to +200
Main Tuner Setup
Tuner Type
LC_TDTC_GXX1D
Thomson DTT7543X
Philips TD1318AF-3
Samsung DTOs403LH172A
Generic ( Analog Only)
Control Byte <.......> Value between 0 to +255
BSW1 <.......> Value between 0 to +255
BSW2 <.......> Value between 0 to +255
BSW3 <.......> Value between 0 to +255
Low-Mid – Low Byte <.......>
Low-Mid – High Byte <.......>
Mid-High – Low Byte <.......>
Mid-High – High Byte <.......>
S Band TOP <.......>
VIF TOP <.......> Value between 0 to +15
VIF TOP SECAM <.......> Value between 0 to +15
VIF TOP DK<.......> Value between 0 to +15
Synch Threshold<.......> Value between 0 to +40
16.4. Options
Options-1
Power Up
Standby
Last state
TV Open Mode
Source
1st TV
Last Tv
First APS <.......>
If “Yes” selected, first time TV opens by asking APS.
APS Volume <.......> Value between 0 to +63
Burn In Mode <.......>
If “Yes” selected, TV opens with Burn-In mode. This mode is
used in manufacturing.
APS Test
Autostore <.......>
If “Yes” selected, Channel is automatically stored.
Unicode Enabled <.......>
If “Yes” selected,Unicode characters can be read in the USB
Files.
Options-2
Source List menu <.......>
If “Yes” selected, Sorce List Menu appears on the screen
when press “source” button.
RS232 for B2B <.......>
If “Yes” selected, Remote Control commandsthe TV via
RS232 and vice versa.
RC Select <.......>
RC Group 1
RC Group 2
RC Group 3
RC Group 4
RC Group 5
RC Group 6
Double Digit Key <.......>
If “Yes” selected, Double Digit Button on RC activates.
Protection <.......>
If “Yes” selected,short circuit protection activates.
Led Type <.......>
1 Led 1 Color
1 Led 2 Color
2 Led 2 Color
1 Led 3 Color
2 Led 3 Color
200 Programme <.......>
If “Yes” selected, totaly 200 programmes can be used.
TouchPad <.......>
If “Yes” selected, TouchPad can be used.
Teletext Options
TXT Darkness <.......> Value between 0 to +63
TXT Type <.......>
Fasttext&Toptext
No
Default
Fastext
Toptext
TXT Language <.......>
Menu
West
East
Cyrillic
Turk/Gre
Arabic
Persian
Auto
No Txt Warning <.......>
If “Yes” selected, “No Txt Transmission” warning appears on
the screen when pressing txt button from RC.
Txt Subtitle <.......>
If “Yes” selected, Teletext subtitles can be seen.
Optional Features
Default Zoom <.......>
Menu
16:9
4:3
Panaromic
14:9 Zoom
Menu Timeout <.......>
Menu
15 Sec
30 Sec
60 Sec
No Time
Backlight <.......>
If “Yes” selected, “Backlight” feature is active.
100 Step Slider <.......>
If “Yes” selected, 64 step sliders will become 100 stepsliders.
Analog USB Enabled <.......>
If “Yes” selected, “Analog USB” option is active.
Menu Double Size <.......>
If “Yes” selected, menu sizes increases.
CEC Enable <.......>
If “Yes” selected, “CEC” feature is active.
Digital USB Hotplug <.......>
If “Yes” selected, “Digital USB Hotplug” feature is active.
PIP Options
Pip <......>
AV PIP
No PIP
PC PIP
Hotel Options <......>
Hotel TV <......>
If “Yes” selected, “Hotel TV” feature is active.
IR Smartloader <......>
If “Yes” selected, “IR Smartloader” feature is active.
16.5. External Source Settings
TV <.......>
DTV <.......>
Ext 2 <.......>
Ext 2 S <.......>
FAV <.......>
BAV <.......>
S-Video <.......>
HDMI 1 <.......>
HDMI 2 <.......>
HDMI 3 <.......>
HDMI 4 <.......>
YPbPr <.......>
PC <.......>
16.6. Preset
User Ad.j
ADC Adj.
Service Adj.
All Adj.
Init Factory Channels.
16.7. NVM Edit
NVM-edit addr. (hex)
NVM-edit data (hex)
NVM-data dec
16.8. Programming
HDMI DDC Update Mode <.......>
HDCP Key Update Mode <.......>
Software Bypass <.......>
If “On” selected, speaker effects are bypassed.
LVDS Clock Step <.......> Value between 0 to +255
Memory Clock Step <.......> Value between 0 to +255
DTV Download <.......>
If “On” selected, DTV software can be updated from SCART.
DSUB9 Download <.......>
If “On” selected, DTV software can be updated from DSUB9.
16.9. Diagnostic
Eeprom I2C
Tuner I2C
IF I2C
HDMI I2C
DTV RS232
16.10. Product Info
Non trovo alcun Factory Menu...
  • Risposte 86
  • Created
  • Ultima risposta
Top Posters In This Topic
  • Marco De Bortoli
    33
  • Elettroda
    22
  • 3kek1
    8
  • mistertv
    5
puoi postare qualche foto dei vari menu' "normali" anziche' quelli in service mode ??? vediamo prima cosa si puo' fare da li.......
nel service mode , se non sei pratico , si fanno danni seri ..... :wacko: :wacko: :wacko:
Prova a fare un factory reset da menu ,al riavvio scegli Italia.
Marco De Bortoli
Allora la situazione è questa:
Se riavvio il setup da tv analogica riesco a settare Italia come paese, ma ovviamente non carico alcun canale (analogico).
Se riavvio il setup dal digitale NON riesco a settare altro che Great Britain, pur con menù italiano, caricando i canali senza LNC e con lingua audio principale che può essere solo inglese, scozzese e gaelico (!). Poi manualmente, se ad esempio il programma è multilingue, posso scegliere l'audio in italiano (che però è sempre come seconda opzione quando c'è anche l'inglese tra le tracce audio).
Non esiste nel menu un Factory Reset.
Perciò concludendo se anche entro con l'analogico in Italiano, quando passo al digitale terrestre i menù cambiano e diventano "inglesi", anche se espressi in italiano.
Spero di essere stato chiaro :senzasperanza:
Avrei scoperto anche come caricare un firmware nuovo, se lo trovassi, tramite scart (in questo modello non esiste nè usb, nè una porta seriale).
Con un decoder esterno ho comunque per il momento risolto, facendo fare a lui tutto il lavoro.
Un'ultima cosa: pur avendo accertato che è un HD Ready, i canali HD non vengono risolti. Sento solo l'audio ed una scritta che dice che il formato video non è supportato...
Direi che è un televisore schizofrenico dalla doppia personalità. :unsure:
La scart non è adatta a far transitare il segnale HD, questo lo ottieni solo con decoder dotati e collegati al tv attraverso le prese HDMI. Io penso che dal menu di servizio riusciresti a fare l'impostazione del sistema riportandolo per l'Italia. C'e' da perdere un pò di tempo nel cercare la voce giusta nel menu di servizio.
Marco De Bortoli
Ho scoperto due cose: la prima è che esiste un service menu Hotel TV in cui si entra con MENU 7935 (scoperta per caso guardando un video youtube).
Detto questo premetto che ho scoperto che nel mio TV la funzione HOTEL MODE è ON sul service menu e tale rimane anche se, dal menu 7935, la metto su OFF.
E' forse per questo che certe opzioni non riesco a modificarle (sono colorate in grigio)?
Fino a stasera non posso far nulla, però credo che se riuscissi a sbloccare la funzione hotel si aprirebbero più possibilità.
Puoi accedere alle funzioni del modo hotel partendo dall'analogico e digitandoMENU,1,3,2,5. Vedi se da questo menu riesci a metterlo OFF perchè dal service non lo puoi fare ma ricevi solo l'informazione che esso è attivo.
Marco De Bortoli
La sequenza MENU 1325 non mi fa accedere. Ho trovato invece funzionante MENU 1461, ma anche così non riesco a togliere la modalità Hotel...
Marco De Bortoli
Concluderei questo thread in quanto sono comunque soddisfatto della riparazione che, nonostante il problema della funzione hotel, è sicuramente andata a buon fine grazie all'aiuto di tutto il Forum che ringrazio veramente di cuore :clap: .
Posso dire che ho risolto il problema "hotel" collegando un decoder esterno full hd (Vodafone TV Solution - tra l'altro acquistato online per 15 €) che fa lui tutto il lavoro in maniera egregia e soddisfacente. Per una TV che era destinata alla discarica non è male.
Grazie ancora a tutti e... alla prossima tv!
Senza che vai ad impegnarti in azioni dal dubbio esito, tipo reset eprom o riprogrammazione della stessa, va bene cosi.
...forse tendendo premuto 10 sec il tasto EXIT sul telecomando , fai il reset totale di fabbrica e quindi la puoi reimpostare in modalita' Home...
(di solito le MAIN vestel sulle samsung hanno questa funzione.... provare non ti costa niente...ma non so' se vale anche per la tua TV...boh)
