Mr-mg30 Mitsubishi - Informazioni
C'è qualcuno che mi sa dire dove posso trovare informazioni su questo "aggeggio" della mitsubishi appena uscito?
E' un gateway profibus per collegare gli azionamenti MR-J2S e all SCS non ne sanno molte più di me
L'aggeggio in questione altro non e' che un ponte tra la rete proprietaria Mitsubishi (SSCNET) ed il profibus. Quindi con installato l mg30 gli azionamenti serie mrj2s (serie B con rete)mantengono le stesse caratteristiche ma i parametri ed i comandi possono essere dati da un master profibus che a sua volta puo' leggere lo stato e le condizioni.
Ulteriori particolari:
MR-MG30 Gateway from Mitsubishi Electric links leading network technologies
The new Profibus gateway
MR-MG30 enables seamless integration of servo systems on Mitsubishi's SSCNET motion control network (Servo Systems Control NETwork) to be directly connected to Profibus, the open fieldbus network.
The new MR-MG30 gateway makes it possible to use all the many advanced features of Mitsubishi Electric’s servo systems in Profibus environments. In addition to exceptionally dynamic performance and ultra-short positioning times these features also include automatic configuration functions like Real Time Autotuning (RTAT) and Automatic Vibration Suppression. These functions, which are standard on Mitsubishi servos, enable users to rapidly configure and optimise their drive solutions for the specific requirements of their applications. The result is an ideal configuration for both maximum performance and a long service life. With the MR-MG30 gateway you can use a single Profibus network link to control up to six servo amplifiers connected to the Mitsubishi SSCNET motion control network. No special SSCNET programming is required.
Mitsubishi’s comprehensive line of high-performance servo systems with outputs from 50W to 110kW enables engineers to configure exactly the right drive solutions for a huge range of applications. The high encoder resolution of 131,072 impulses per revolution ensures maximum precision for all output capacities.
Connection via the MR-MG30 gateway is only one option, of course – Mitsubishi Electric also offers more complex motion control solutions. Here too, Mitsubishi’s SSCNET motion control network provides data communications in both directions between the servo amplifier and the motion controller. This high-speed network delivers exceptional performance, with an update time of just 0.88ms for all amplifiers connected to the bus. SSCNET can synchronise a total of up to 96 axes.
Modificato: da andreoni
