sample0527 Inserito: 16 maggio 2015 Segnala Inserito: 16 maggio 2015 Beause Siemens TD200 has been discontinued,I still need to use some of the machinery.I nedd td200 alternatives.Can anyone tell me what the product can replace TD200?TD200 alternatives need not be Siemens brand, but you can replace the TD200 and the complete program without modification S7200PLC and need CE and UL. I found VIPA TD 03 Text Display but I'm not sure whether you can replace the TD200?
Gioacchino Vitale Inserita: 24 luglio 2015 Segnala Inserita: 24 luglio 2015 (modificato) Well, they looks like the same...just check dimensions and com interfaces! Have a look www.kernelgroup.it/vtm-322.html as well Good luck Modificato: 24 luglio 2015 da Gioacchino Vitale
