logoenthu Inserito: 5 dicembre 2015 Segnala Inserito: 5 dicembre 2015 Hi i bought a brand new 6ed1052-1md00-0ba8 (Logo 8) PLC and want to get a safe first startI am a complete newbe to PLCs so i have some confusion about connections and wiring.by reading the manual i made the following schematic,but i want to ask that,i have marked the points below with the same number encircled red in the above image1. i found i have to connect "Ground" near the RJ45 ethernet port, now my confusion is that I am using a DC power supply with only two pins + and - so should i connect this "Ground" to the - (negative) wire of my supply, clearly i mean that i short this "Ground" and "M' of the logo 8 ------- is it OK2. the second confusion is that I could not find the current limit of inputs of logo whether i connect fuse (750mA,250 V or what value) to each input I1, I2 ... I8 that i use along with on main supply L+ 3. should i use a fuse for o/p relay contacts for their protectionpls reply soon I am curious to use my PLCthanks in advance
rfabri Inserita: 5 dicembre 2015 Segnala Inserita: 5 dicembre 2015 The pattern that you have made is fine, unless you are using as a load led the R 10k otherwise not needed, while for protection inputs are already protect evironmentals not need anything, bye
logoenthu Inserita: 6 dicembre 2015 Autore Segnala Inserita: 6 dicembre 2015 lots of thanks for replythat means i don't need anything (fuse or resister) for switches attached to inputs I1, I2,.... only fuse at L+ is needed ---------- am i right?and also i can connect the "Ground" near the RJ45 ethernet port ( numbered encircled 1 ) to the negative terminal of my 12V 1A dc adaptor ------ am i right?pls answer above two questions clearly, that will clear my confusions completely and then i will give my plc a safe first startthanks in advance
rfabri Inserita: 6 dicembre 2015 Segnala Inserita: 6 dicembre 2015 Go quiet for the first two answers to the problem rj 45 must connect only ground, so no to negative, bye
logoenthu Inserita: 6 dicembre 2015 Autore Segnala Inserita: 6 dicembre 2015 Means rj45's ground terminal i should not connect to negative of 12 v adaptor?, then to where i should connect it or leave floating, pls tell clearly, i m a newbeTha nks
logoenthu Inserita: 6 dicembre 2015 Autore Segnala Inserita: 6 dicembre 2015 Hi pls dont mind asking again and again, but with dc adaptor i have no option of ground, only positive and negative terminals are there, so how i connect the ground of my plc, or leaving unconnected is no problem?Pls reply soonThanos
rfabri Inserita: 6 dicembre 2015 Segnala Inserita: 6 dicembre 2015 If you have no possibility to connect to the chassis ground do not connect anything, bye
