MPLAB X IDE v3.25: Dov'è l'errore?
Salve a tutti.
Sto cercando di migrare un progettino da MikroC a MPLAB X v3.25. Per rendere la cosa più facile, integro piccole parti e correggo eventuali errori.
Non riesco però ad assegnare a qualsiasi ingresso o  uscita una variabile. Se nel programma leggo/scrivo direttamente la porta, la compilazione va a buon fine
 * File:   Battery_Saver.c
 * Author: Stefano T.
 * MCU:    PIC12F1840
 * Created on 31 gennaio 2016
// Registri configurazione
#include <xc.h>
#include <stdlib.h>
#include <stdio.h>
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config CPD = OFF        // Data Memory Code Protection (Data memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = ON        // Internal/External Switchover (Internal/External Switchover mode is enabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config PLLEN = ON       // PLL Enable (4x PLL enabled)
#pragma config STVREN = ON      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LVP = ON         // Low-Voltage Programming Enable (Low-voltage programming enabled)      // Low-Voltage Programming Enable (Low-voltage programming enabled)     // Low-Voltage Programming Enable (Low-voltage programming enabled)
// Configurazione Frequenza Clock
#define _XTAL_FREQ 800000
//****** TAGs ******************************************************************
       unsigned int Dc1, Dc2, Dc3;
       unsigned int AnVal1, AnVal2;
       float In_min, In_max, Out_min, Out_max, ActVolt, Reference;
// Defining Voltage treholds
       float Ready  =12.5;
       float Warning=12.;
       float Alarm  =11.8;
// PINs association
      #define Mos	PORTAbits.RA2;  // Nmos gate
      #define LedG	PORTAbits.RA4;
      #define LedR	PORTAbits.RA5;
void main(void) {
// Registri configurazione PORT[A]
       WPUA    = 0b00000000;    // Resistenze Pull Up disattivate
       APFCON  = 0b00000000;    // Alternate Pin Function
       TRISA   = 0b11001011;    // RA2-RA4-RA5=OUT - RA0-RA1-RA3=INPUT
       LATA    = 0b00000000;    // PORT[A] Latch register
       ANSELA  = 0b00000011;    // Ingressi Anaogici RA0-RA1
// Registri configurazione INTERRUPTS
       INTCON  = 0b00000000;    // INTERRUPTS CTRL REGISTER
       PIE1    = 0b00000000;    // PERIPHERAL INTERRUPT ENABLE REGISTER 1
       PIE2    = 0b00000000;    // PERIPHERAL INTERRUPT ENABLE REGISTER 2
       PIR1    = 0b00000000;    // PERIPHERAL INTERRUPT REQUEST REGISTER 1
       PIR2    = 0b00000000;    // PERIPHERAL INTERRUPT REQUEST REGISTER 2
       IOCAP   = 0b00000000;    // INTERRUPT-ON-CHANGE PORT[A] POS.EDGE REGISTER
       IOCAN   = 0b00000000;    // INTERRUPT-ON-CHANGE PORT[A] NEG.EDGE REGISTER
       IOCAF   = 0b00000000;    // INTERRUPT-ON-CHANGE PORT[A] FLAG REGISTER
// REGISRTI AD
       ADCON1    = 0b10010000;    // Right Justfied - AD Clk = Fosc/32 = 1uS
	In_min=0;
	In_max=1023;
	Out_min=0.;
	Out_max=5.;
      while(1)
// Lettura AN0 - RA0
	 ADCON0bits.CHS0 =0;          // BIT0 - AN SELECTOR |
         ADCON0bits.CHS1 =0;          // BIT1 - AN SELECTOR |
         ADCON0bits.CHS2 =0;          // BIT2 - AN SELECTOR |- RA0 SELEZIONATO
         ADCON0bits.CHS3 =0;          // BIT3 - AN SELECTOR |
         ADCON0bits.CHS4 =0;          // BIT4 - AN SELECTOR |
         ADCON0bits.ADON =1;          // ATTIVO CONVERTITORE AD
         __delay_us(6);               // ATTENDO 6us
         ADCON0bits.GO   =1;          // ATTIVO LA CONVERSIONE
         __delay_us(11);              // ATTENDO 11us
	     AnVal1          =ADRES;      // TRASFERISCO VALORE AD SU VARIABILE
         ADCON0bits.GO   =0;          // DISATTIVO LA CONVERSIONE
         ADCON0bits.ADON =0;          // DISATTIVO CONVERTITORE AD
// Lettura AN1 - RA1
         ADCON0bits.CHS0 =1;          // BIT0 - AN SELECTOR |
         ADCON0bits.CHS2 =0;          // BIT2 - AN SELECTOR |- RA1 SELEZIONATO
         AnVal2 	 =ADRES;      // TRASFERISCO VALORE AD SU VARIABILE
// CTRL limiti
         if(AnVal1<In_min)AnVal1=In_min;
         if(AnVal1>In_max)AnVal1=In_max;
	     if(AnVal2<In_min)AnVal2=In_min;
         if(AnVal2>In_max)AnVal2=In_max;
// Floating Point Scaling - Conversione in Volt
  ActVolt  =(Out_min+(((AnVal1-In_min)/(In_max-In_min))*(Out_max-Out_min)));
  Reference=(Out_min+(((AnVal2-In_min)/(In_max-In_min))*(Out_max-Out_min)));
// Controllo tensione
   PORTAbits.RA4=(ActVolt<=Reference);
se invece sostituisco la porta con la sua dichiarazione associata ad una variabile, ottengo un errore di sintassi....
dove sbaglio?
Grande! L'ho riguardato centinaia di volte e non me ne sono mai accorto! :wallbash:
....perché sbagliavo proprio!
Grazie :thumb_yello:
#define _XTAL_FREQ 800000 // manca uno zero per gli 8MHz!!!
Ho provato a compilarlo al volo e non mi ha dato errori di nessun genere anche senza la modifica suggerita...
A me col punto e virgola non lo compila....anzi...in proteus8.3 lo compila in mplab x invece no.
Per lo zero.....hai ragione.....:thumb_yello:
