CP341 MODBUS MASTER
Salve a tutti vorrei chiedere un aiuto per l'utilizzo di un CP341 modbus master, dovrei dialogare con uno slave.
Ho letto i manuali è ho eseguito passo passo le istruzioni,la comunicazione TXD e RXD si vede i led lampeggiano,l'idirizzo dello slave e 1 e la funzione e la 3 ma non riesco a capire perchè non leggo i valori dei registri dello slave.
Qualcuno può darmi un suggerimento?
Salvo B.
Ho provato con il file di esempio Siemens :
     U     M    120.7                  //Trigger SEND
      UN    DB40.DBX    0.0             //SEND_REQ
      UN    DB40.DBX    0.4             //SEND_DONE
      UN    DB40.DBX    0.5             //SEND_ERROR
      R     M    120.7                  //Reset Trigger BSEND
      S     DB40.DBX    0.0             //Set SEND_REQ
// Generate edge SEND_REQ
      U(
      O     DB40.DBX    0.4             //SEND_DONE
      O     DB40.DBX    0.5             //SEND_ERROR
      U     DB40.DBX    0.0             //SEND_REQ
      R     DB40.DBX    0.0             //SEND with REQ=0
// Supply LEN
      L     W#16#20                     //Length SEND-Data
      T     DB40.DBW   10               //SEND LEN
// SEND with Instance-DB
      CALL  "P_SND_RK" , "IDB_P_SND_RK"
       SF      :='S'
       REQ     :=DB40.DBX0.0
       R       :=DB40.DBX0.1
       LADDR   :=272
       DB_NO   :=42
       DBB_NO  :=0
       LEN     :=8
       R_CPU_NO:=
       R_TYP   :='X'
       R_NO    :=
       R_OFFSET:=
       R_CF_BYT:=
       R_CF_BIT:=
       DONE    :=DB40.DBX0.4
       ERROR   :=DB40.DBX0.5
       STATUS  :=DB40.DBW12
// Check "Complete without error"
      U     DB40.DBX    0.4             //DONE ?
      SPBN  CON1                        //if NO
      L     DB40.DBW    6               //"Complete without Error"
      +     1                           //increment counter
      T     DB40.DBW    6
      NOP   0
      NOP   0                           //further user functions
      NOP   0
      SPA   LEAV
// Check "Complete with error"
CON1: U     DB40.DBX    0.5             //ERROR ?
      SPBN  CON2                        //if NO
      L     DB40.DBW    8               //"Complete with error"
      T     DB40.DBW    8
      NOP   0
      NOP   0                           //Error-Handling
      NOP   0
      L     0
      L     DB40.DBW   12               //if STATUS <> 0
      ==I
      SPB   LEAV
      T     DB40.DBW   14               //save STATUS
      SPA   LEAV
// Check "Error in STATUS"
CON2: L     0
      ==I
      SPB   LEAV
      NOP   0                           //
      NOP   0
LEAV: CLR
      SET
      =     DB41.DBX    0.0             //RCV with EN_R=1
// RCV with Instance-DB
      CALL  "P_RCV_RK" , "IDB_P_RCV_RK"
       EN_R    :=DB41.DBX0.0
       R       :=
       LADDR   :=DB41.DBW16
       DB_NO   :=43
       DBB_NO  :=0
       L_TYP   :=
       L_NO    :=
       L_OFFSET:=
       L_CF_BYT:=
       L_CF_BIT:=
       NDR     :=DB41.DBX0.4
       ERROR   :=DB41.DBX0.5
       LEN     :=DB41.DBW10
       STATUS  :=DB41.DBW12
// Check "Receive without error"
      U     DB41.DBX    0.4             //NDR ?
      SPBN  CON1                        //if NO
      L     DB41.DBW    6               //"Receive without error"
      T     DB41.DBW    6
      L     DB41.DBW   10               //save RECEIVE-Length
      T     DB41.DBW    4
      SPA   LEAV
// Check "Receive with error"
CON1: U     DB41.DBX    0.5             //ERROR ?
      SPBN  CON2                        //if NO
      L     DB41.DBW    8               //"Receive with error"
      T     DB41.DBW    8
      L     0
      L     DB41.DBW   12               //if STATUS <> 0
      ==I
      SPB   LEAV
      T     DB41.DBW   14               //save STATUS
      SPA   LEAV
CON2: L     0
      ==I
      SPB   LEAV
LEAV: CLR
Non riesco a leggere i valori dei registri:
Niente da fare avro letto il manuale 20 volte, sembra essere tutto apposto non riesco proprio a capire dove leggere il lavore dei registri dello slave.
:toobad:
Scusa una domanda che slave stai usando ? Stai comunicando con un PLC slave ?
dcsautomazione
Ciao no si tratta di un sistema di pesatura a canali vibranti con celle di carico per materiali inerti a granuli e una centralina bilanciai.
Salvo B.
I dati te li trovi nel db43 dal byte 0 in poi. Gli fb non ti restituiscono errori? Nel buffer di diagnostica della CPU ci sono errori riguardo a questa comunicazione?
Verifica bene il codice dell'esempio: mi ricordo che nel programma Siemens c'è un errore, mi sembra sul puntamento ai merker di appoggio di trasferimento, non ricordo bene dove, ma c'è.
dcsautomazione
Ciao busanella credo che ci sia proprio qualcosa che non va e poi non riesco a leggere tutti i valori in una sola volta esempio se dico leggi dal registro 1 al 150 non legge tutto smette di lampeggiare pure il led rx massimo che posso scrivere e 127.
se scrivo leggi dal 50 al 100 allora li legge ma quelli che stanno dal 1 al 49 e tutto a zero.
s.b
