petrera Inserito: 29 aprile 2009 Segnala Inserito: 29 aprile 2009 Ciao a tutti del forum, chiedo cortesemente chi può aiutarmi a decifrare allarme AL-12 su un servodriver FANUC - A06B-6059-K032.Grazie
eddy1972 Inserita: 2 maggio 2009 Segnala Inserita: 2 maggio 2009 ho gia inviato lo stesso messaggio sull'altra discussione spero ti aiuti ciao. > Home > Fanuc > Siemens > FAQ > Directory > KME Monitors > Jobs > Text Version > AccessibiltyFanuc Alpha axis and spindle alarm codes *> Fanuc Power Supply> Fanuc Monitors> Fanuc Control Parts> Fanuc Drives*Fanuc Alpha axis and spindle alarm codes*> CONTACT DETAILS> Fanuc Power Supply> Fanuc Alarm Codes> Alpha Power Supply> Fanuc . And Tips> Fanuc Systems Packing> Resources> Fanuc Sensor> Promotions / Sale Items> Fanuc Batteries> Fanuc GE CNC About> Site Map*> Fanuc A61L-0001-0072> Fanuc A61L-0001-0074> Fanuc A61L-0001-0076> Fanuc A61L-0001-0077> Fanuc A61L-0001-0079> Fanuc A61L-0001-0086> Fanuc A61L-0001-0087> Fanuc A61L-0001-0092> Fanuc A61L-0001-0093> Fanuc A61L-0001-0095> Fanuc A61L-0001-0094> Fanuc A61L-0001-0096*> GE Fanuc Memory> Fanuc Master Board> Fanuc MDI / Crt Panel> Graphic Boards> Fanuc 10 Control Parts> Fanuc 11 Spares> Fanuc Keysheets> Fanuc Repair Service> Fanuc Control History> Fanuc 15 Spare Parts> Fanuc A03B Modules> Fanuc Zero A,B,C,D*> Drive Card ( Axis )> Drive Card ( Spindle )> Fanuc Encoders> Orientation Board> Fanuc Servo Motor> Fanuc Alarm Codes> Transistor Modules> Fanuc Alpha Servo> Fanuc DC Motor> Fanuc Beta Motors> S Series Motors> Fanuc*> Site SearchPennine Machine Tools LtdBrookwoods Industrial EstateHolywell Green HalifaxWest YorkshireHX4 9BH Englandsales[at]pennineuk.comCom Reg No 3132574VAT No GB 640792433Tel:+44 (0) 1422 370109Fax:+44 (0) 1422 371338email:click hereFanuc Alpha axis and spindle alarm codesfanuc alpha alarm codesDetails on fanuc alpha spindle drive and fanuc alpha axis drive fault codes hope this page helps you find the fault with your fanuc drive if not send your fanuc drive to us for a free quote to repair iAlarms on Fanuc Alpha Servo Drive's1 :Over-voltage alarm (HV)2 :Low control power voltage alarm (LV)3 :Low DC link voltage alarm (LVDC)4 :Regenerative dis-charge control circuit failure alarm (DCSW)5 :Over-regenerative discharge alarm (DCOH)6 :L-and M-axis over-current alarm (HCM)6. :L-and M-axis IPM alarm (IPMLM)7 :Dynamic brake circuit failure alarm (DBRLY)8 :L-axis over-current alarm (HCL)8. :L-axis IPM alarm (IPML)9 :M-axis over-current alarm (HCM)9. :M-axis IPM alarm (IPML)Alarms on Fanuc Alpha Spindle Drive'sAL-01 : MOTOR OVERHEATAL-02 : EX SPEED ERRORAL-03 : FUSE ON DC LINK BLOWNAL-04 : INPUT FUSE/POWER FAULTAL-05 : POWER SUPPLY FUSE BLOWNAL-07 : OVERSPEEDAL-08 : HIGH VOLT IN-PUT POWERAL-09 : OVERHEAT MAIN CIRCUITAL-10 : LOW VOLT IN-PUT POWERAL-11 : OVERVOLT POW CIRCUITAL-12 : OVERCUR-RENT POW CIRCUITAL-13 : DATA MEMORY FAULT CPUAL-15 : SP SWITCH CONTROL ALARMAL-16 : RAM FAULTAL-18 : SUMCHECK ERROR PGM DATAAL-19 : EX OFFSET CURRENT UAL-20 : EX OFFSET CURRENT VAL-24 : SERIAL TRANSFER ERRORAL-25 : SERIAL TRANSFER STOPAL-26 : DISCONNECT C VELO DETECTAL-27 : DISCONNECT POS-CODERAL-28 : DISCONNECT C-POS DE-TECTAL-29 : SHORTTIME OVERLOADAL-30 : OVERCURRENT POW CIRCUITAL-31 : MOTOR LOCK OR V-SIG LOSAL-32 : RAM FAULT SERIAL LSIAL-33 : SHORTAGE POWER CHARGEAL-34 : PARAMETER SETTING ERRORAL-35 : EX SETTING GEAR RATIOAL-36 : OVERFLOW ERROR COUNTERAL-37 : SPEED DETECT PAR. ERRORAL-39 : 1-ROT Cs SIGNAL ERRORAL-40 : NO 1 ROT Cs SIGNAL DETECTAL-41 : 1-ROT POSCODER ERRORAL-42 : NO 1-ROT. POSCODER DETECTAL-43 : DISCON. PC FOR DIF. SP. MOD.AL-44 : CONTROL CIRCUIT(AD) ERRORAL-46 : SCREW 1-ROT POSCOD. ALARMAL-47 : POS-CODER SIGNAL AB-NORMALAL-49 : HIGH CONV. DIF. SPEEDAL-50 : SPNDL CON-TROL OVER-SPEEDAL-51 : LOW VOLT DC LINKAL-52 : ITP SIGNAL ABNORMAL IAL-53 : ITP SIGNAL ABNORMAL IIAL-56 : INNER COOLING FAN STOPAL-57 : EX DECEL-ERATION POWERAL-58 : OVERLOAD IN PSMAL-59 : COOLING FAN STOP IN PSM. Pages Index> Copyright © 2009 Pennine Machine Tools Ltd. All rights reserved
petrera Inserita: 2 maggio 2009 Autore Segnala Inserita: 2 maggio 2009 Grazie eddy, almeno adesso so di cosa si tratta.
