walterword Inserito: 3 luglio 2016 Segnala Inserito: 3 luglio 2016 questo è un file che ho scritto per regolare temperature Si tratta di un regolatore P.I. con uscita anche pwm. FUNCTION_BLOCK FB80 // Digital regulator P.I.D. Written by Walter P. 05/06/2009 VAR_INPUT Set_Point:REAL ; // Set point value Feedback:REAL ; // Feedback value process Kp:REAL; // K Proportional gain Ki:REAL; // K Integral gain Max_Analog:REAL; // Maximum value for analog output Max_Time_Cycle:REAL; // Maximum time cycle for PWM digital output (milliseconds) Scan_Time:REAL; // Scanning time of the plc Time_Sample:REAL; // Time sample in OB35 Enable:BOOL; // Enable PWM digital P.I.D. Reset:BOOL; // Reset regulator END_VAR LABEL salto; end_label VAR_IN_OUT END_VAR VAR_OUTPUT Out_Analog_Reg:REAL ; // Output analog regulation Duty_Cycle_Perc:REAL; // Duty cycle On percentage Wave_On_PWM:BOOL; // Output high wave On of digital PWM Wave_Off_PWM:BOOL; // Output low wave On of digital PWM END_VAR VAR_TEMP END_VAR VAR Error:REAL ; // Error for each scan I_Ist:REAL; // Istant I:REAL ; // Integral memory P:REAL; // Proportional component Accu_Timer:REAL; // Timer Accumulator for the duty cycle PWM Thr_Wave_On:REAL; // Threshold for the wave ON Thr_Wave_Off:REAL; // Threshold for the wave OFF Wave_On:BOOL; // Wave On Wave_Off:BOOL; // Wave Off END_VAR BEGIN Error:=Set_Point - Feedback ; P:=Error * Kp * 1000.0 ; I_Ist:=Error * Ki; I:=I + I_Ist ; IF I <= 0.0 THEN I:=0.0; END_IF; IF I >= Max_Analog*0.8 THEN I:=Max_Analog*0.8; END_IF ; IF Enable=true THEN Out_Analog_Reg:=P + I ; END_IF; IF Reset THEN P:=0.0; I:=0.0; I_Ist:=0.0; Out_Analog_Reg:=0.0; Wave_On:=false; Wave_Off:=false; Accu_Timer:=0.0; END_IF; IF Out_Analog_Reg >= Max_Analog THEN Out_Analog_Reg:=Max_Analog;END_IF; IF Out_Analog_Reg <= 0.0 THEN Out_Analog_Reg:=0.0; END_IF; // STATE OF ENDED MACHINE TO GENERATE THE WAVE SQUARED ON AND OFF OF THE PWM Thr_Wave_On:= (Max_Time_Cycle / Max_Analog) * Out_Analog_Reg; Thr_Wave_Off:=Max_Analog - Thr_Wave_On; IF Accu_Timer=0.0 AND Enable THEN Wave_On:=true; Wave_Off:=false; END_IF; IF Wave_On=true THEN Accu_Timer:=Accu_Timer + Time_Sample; Duty_Cycle_Perc:=(Thr_Wave_On / Max_Time_Cycle) * 100.0; IF Accu_Timer >= Thr_Wave_On THEN Wave_On:=false; Wave_Off:=true; END_IF; END_IF; IF Wave_Off=true THEN Accu_Timer:=Accu_Timer + Time_Sample; IF Accu_Timer >= Max_Time_Cycle THEN Wave_Off:=false; Accu_Timer:=0.0; GOTO salto ; END_IF; END_IF; salto: Wave_On_PWM:= Wave_On AND Thr_Wave_On>= 1000.0; Wave_Off_PWM:=Wave_Off ; ; END_FUNCTION_BLOCK
pigroplc Inserita: 4 luglio 2016 Segnala Inserita: 4 luglio 2016 semplice ed intuitiva, riagganciandomi all'altra discussione in corso ....... falla in KOP!
walterword Inserita: 6 luglio 2016 Autore Segnala Inserita: 6 luglio 2016 in kop si potrebbe anche fare , non ci sono tipi di dati bytes , non ci sono caratteri etc . Però non ha senso
