Lavastoviglie indesit dif15
Tonino Bochicchio
Tonino Bochicchio
Buongiorno ho un problema con la mia lavastoviglie indesit dif 14 lampeggiamo i led on/off più il primo partendo da sinistra (eco ..)qualcuno mi può aiutare grazie
Link al commento
Condividi su altri siti
F06
Indesit Dishwasher Error code
Water fill timeout fault
Issue: The LED lights on your dishwasher are displaying in the following sequence
  • LED 1: OFF
  • LED 2: ON
  • LED 3: ON
  • LED 4: OFF
Action: Please check that the water supply is present and of sufficient pressure, also that the tap is fully on and that the fill hose is not restricted or kinked. Check that water is going to the dishwasher, the valve is working correctly, the impeller jug is functioning correctly, also check the water chamber has no restrictions on the flow rate, if the dishwasher cant fill in the correct amount of time the you will get an error.
Link al commento
