Controllare impianto Vimar By-Me con OpenHab e Raspberry Pi2
ciao,
I was searching the internet for other people using the vimar system and it seems you are pretty advanced on this topic.
I have the folling components in my setup:
  • 21554.B Video Touch 4.3 Color
  • 01945 IP Web Server
  • 21509 Central Touch Screen
  • 01998 BUS-to-Serial Interface
the IP Web Server works so far - but in hindsight it is by far not that what I expected. I wish for any IFTTT, alexa, or google home integration. Thats why I tried to implement a wrapper for the webserver to send custom commands over http. I got this working, but is very slow. Also I would have to implement all custom commands (like timers or external interfaces) by myself. A direct interface to the bus and an integration to openhab or Domoticz would be great - I also have a synology server and spare rasperry3 for this.
I am not yet through with this thread (sorry, my Italian understanding is very limited) but as far as I understood, I need this ESP_SCSGATE. Is this right?
Any . would be appreciated. Also I am just making this post, so you know I am on this topic as well :)
Best regards
  • 7 months later...
I just found out, that my post (above) did not get deleted, but just moved to another forum - this above was meant to be in https://www.plcforum.it/f/topic/194944-controllare-impianto-vimar-by-me-con-openhab-e-raspberry-pi2/ - so maybe it does make more sense now.
Also I wanted to post a link to an integration in PHP, that mimics the web requests on the webserver (mostly direct sql statements … )  https://github.com/h4de5/VimarWebserverApi
(its WIP - so don’t expect much)
If someone is interested or is able to ., feel free to reply
  • 1 year later...
Here is an update!
I moved away from the standalone PHP implementation to a python integration for home-assistant.io
https://github.com/h4de5/home-assistant-vimar
https://community.home-assistant.io/t/vimar-integration-wip/202073
So far you can - if you have the by-me webserver (01945) - control lights, switches, fans and shades all from the home-assistant's web interface. From there any of the many other integrations can be used to interact with or automate those entities.
1fc5fd43350dd2985bec3151e157f4ea0bd17252
