Map Mikrotik ed INTERNET KEY
Salve, volevo avere connessione internet da un MAP mikrotik collegandoci una Internet Key
Dai forum penso di essere riuscito a configurare il tutto..
Al momento non ho una sim dati per testarla..allego lo script, magari qualcuno sa darmi delucidazioni
# jan/02/1970 01:09:56 by RouterOS 6.36.3
# software id = WZ1U-YBZF
/interface bridge
add name="bridge lan"
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    name="security wifi" supplicant-identity="" wpa-pre-shared-key=fordtest \
    wpa2-pre-shared-key=fordtest
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=15 band=2ghz-onlyn \
    channel-width=20/40mhz-Ce country=italy disabled=no frequency=2442 mode=\
    ap-bridge radio-name=FORD security-profile="security wifi" ssid=\
    Ford_Network wireless-protocol=802.11 wps-mode=disabled
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
/ip pool
add name="POOL DHCP" ranges=84.246.159.100-84.246.159.199
/ip dhcp-server
add address-pool="POOL DHCP" disabled=no interface="bridge lan" name=\
    "dhcp server"
/port
set 0 name=usb1
/interface ppp-client
add apn=web.omnitel.it disabled=no name="Interface KEY USB" port=usb1
/interface bridge port
add bridge="bridge lan" interface=ether1
add bridge="bridge lan" interface=ether2
add bridge="bridge lan" interface=wlan1
/ip address
add address=84.246.159.1/24 interface="bridge lan" network=84.246.159.0
/ip dhcp-server network
add address=84.246.159.0/24 dns-server=10.127.1.41 gateway=84.246.159.1 \
    netmask=24
/ip dns
set servers=10.127.1.41
/ip firewall nat
add action=masquerade chain=srcnat out-interface="Interface KEY USB"
/system identity
set name="MAP FORD"
/system ntp client
set enabled=yes primary-ntp=193.204.114.232 secondary-ntp=193.204.114.233
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
Tralasciando il discorso IP (che non posso sapere se è giusto e perchè viene usata una classe diversa dalle private standard) e che non c'è GW in quanto non è presente la connessione attiva sembra OK.
Dipende però da che tipo di dongle USB utilizzerai. Molti di quelli recenti (es, Huawei) vengono viste dalle RouterBoard non come interfaccie della RB ma come veri e propri modem esterni sui quali è necessario attivare un loro indirizzamento.
E una vecchia chiavetta zte marchiata vodafone....
Il problema mi sa che attualmente non trovo sim dati con promozioni grossomodo ridotte all'osso tipo 500MB badget 5/6 euro mensili
Ho trovato questa
Super Internet 5GB
L'offerta più conveniente!
5GB di internet inclusi. E con GIGA BANK non perdi i tuoi GIGA!
3€ con carta di credito o conto corrente e impegno di 24 mesi
Navigazione LTE con Opzione 4G LTE.
Offerta disponibile fino al 18/02/2018.
Potrebbe funzionare su chiavetta vodafone cambiando l'apn?
La chiavetta è HSPA non 4G
Non c'entra se è 4G o HSPA.....quello è un discorso della chiavetta. Mikrotik gestisce solo la connessione.
Per assicurarti la compatibilità dei chipset vai sul sito mikrotik e controlla quali sono certificate.
come faccio????
la chiavetta è una ZTE modello K3806-Z
Inserito sim 3....impostato apn su datacard.tre.it e selezionano PAP come autenticazione come specificato nel sito 3...
Ora dai log mi rimane in waiting for pack
Poi va su connecting e rimane così
Ho attivato anche i debug e mi scrive usb 1:0 sent +++
usb 1:0sent ATH
