Prese RJ45 connesse "a cascata"
17 ore fa, Andrea Annoni scrisse:
parametri della wireless
/interface bridge
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps country=italy disabled=no \
    frequency=2437 frequency-mode=superchannel mode=ap-bridge rate-set=configured ssid="Avengers I" wps-mode=disabled
/interface ethernet
set [ find default-name=ether1 ] loop-protect=on
set [ find default-name=ether2 ] loop-protect=on
/interface list
add include=all name=WAN
add include=all name=LAN
/interface wireless security-profiles
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk
/interface bridge port
add bridge=bridge1 interface=ether1
add bridge=bridge1 interface=ether2
add bridge=bridge1 interface=ether3
add bridge=bridge1 interface=ether4
add bridge=bridge1 interface=wlan1
/interface list member
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether1 list=WAN
add interface=wlan1 list=WAN
/ip address
add address=192.168.0.22/24 interface=ether2 network=192.168.0.0
/ip dns
set servers=1.1.1.1
/ip route
add distance=1 gateway=192.18.0.1
/system identity
set name="MikroTik 3"
2 ore fa, triumphdyd scrisse:
frequency-mode=manual-txpower
frequency=2437
Prova anche frequency=2412
Imposta Wireles-Protocoll=802.11
4 ore fa, Andrea Annoni scrisse:
Buonasera Andrea e grazie come sempre dei tuoi consigli e della tua pazienza.
Purtroppo facendo le tre modifiche da te consigliatomi, la velocità in WIFI resta sempre intorno ad 1mb mentre con LAN a circa 15 mb...🤔
Grazie ancora
questa la nuova configurazione senza aver risolto il problema della bassa velocità in wifi
/interface bridge add name=bridge1 /interface wireless set [ find default-name=wlan1 ] amsdu-limit=2048 band=2ghz-b/g/n basic-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps \ channel-width=20/40mhz-Ce country=italy distance=indoors frequency=2412 mode=ap-bridge rate-set=configured ssid="Avengers I" tx-power-mode=all-rates-fixed \ wireless-protocol=802.11 wps-mode=disabled /interface ethernet set [ find default-name=ether1 ] l2mtu=1600 loop-protect=on set [ find default-name=ether2 ] l2mtu=1600 loop-protect=on set [ find default-name=ether3 ] l2mtu=1600 set [ find default-name=ether4 ] l2mtu=1600 /interface list add include=all name=WAN add include=all name=LAN /interface wireless security-profiles set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys  /ip pool add name=vpn ranges=192.168.89.2-192.168.89.255 /ppp profile set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn /interface bridge port add bridge=bridge1 interface=ether1 add bridge=bridge1 interface=ether2 add bridge=bridge1 interface=ether3 add bridge=bridge1 interface=ether4 add bridge=bridge1 interface=wlan1 /interface l2tp-server server set ipsec-secret=admin1234 use-ipsec=yes /interface list member add interface=ether2 list=LAN add interface=ether3 list=LAN add interface=ether4 list=LAN add interface=ether1 list=WAN add interface=wlan1 list=WAN /interface sstp-server server set default-profile=default-encryption /ip address add address=192.168.0.22/24 interface=bridge1 network=192.168.0.0 /ip cloud set ddns-enabled=yes /ip dns set servers=1.1.1.1 /ip firewall nat add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=192.168.89.0/24 /ip route add distance=1 gateway=192.18.0.1 /ppp secret add name=vpn password=admin1234 /system identity set name="MikroTik 3"
20 ore fa, triumphdyd scrisse:
distance=indoors
distance= dynamic
channel-width=20mhz
Altro io non vedo...........
tx-power-mode=default
Sono da cel e a prima vista non vedo altro. Se vuoi un consiglio resetta e parti da un conf pulita senza caricare i default
  • 1 month later...
