Philips 55pfs8159 riavvio continuo
Inserito: (modificato)
Ciao a tutti ho questa tv della philips con android il problema e che la tv si riavvia di continuo e non riesco nenache ad accedere alla recovery o collegato la tv alla porta uart e questo e il resoconto.
Spoiler
I2C switch set as 1 --------- I2C Initialization ---------- I2C_INIT: I2C-2 bus I2C_INIT: I2C-1 bus I2C_INIT: I2C-0 bus DDR reg 0xF7CB0BAC value : 0x00021421 DDR reg 0xF7CB0C00 value : 0x00004031 leakage info 464. set Vcpu to 1300mV, default setting by hardware. set Vcore to 1150mV, default setting by hardware. flash_ts_init() success. RDKDMP BG2Q [Oct 27 2017 18:04:12] Pinmux configuration: GSM 0xf7fcd040 0x009c0261; 0xf7ea0014: 00000072 00240611 00000253 1249008a 0xf7ea0028: 01249492 00000048 1ca54009 0430e44d 0xf7ea003c: 00000000 00000000 0000001f 63c06a52 Clock configuration: VCO_B frequency 1620 AVPLLB[4] frequency 300 AVPLLB[5] frequency 800 AVPLLB[6] frequency 1680 AVPLLB[7] frequency 610 cpuPll frequency 1200 memPll frequency 1500 sysPll frequency 800 dClk frequency 375 cpuClk frequency 1200 sysClk frequency 400 drmClk frequency 400 cfgClk frequency 100 gfxClk frequency 400 zspClk frequency 400 perifClk frequency 200 pCubeClk frequency 610 vScopeClk frequency 610 nfcEccClk frequency 100 vppSysClk frequency 400 appClk frequency 800 gfx3DCoreClk frequency 420 gfx3DSysClk frequency 400 arcRefClk frequency 400 vipClk frequency 400 sdioXinClk frequency 200 sdio1XinClk frequency 200 gfx3DShClk frequency 420 avif0Clk frequency 300 avif1Clk frequency 300 [00,sd00] bootloader: part1(start=0, blks=1, version=201710271804), part2(start= 0, blks=1, version=000000000000) [01,sd01] fts: part1(start=32, blks=32, version=201710271804), part2(start=32, b lks=32, version=000000000000) [02,sd02] recovery: part1(start=64, blks=120, version=201710271804), part2(start =64, blks=120, version=000000000000) [03,sd03] tzk_recovery: part1(start=184, blks=8, version=201710271804), part2(st art=184, blks=8, version=000000000000) [04,sd04] factory_setting: part1(start=192, blks=128, version=201710271804), par t2(start=192, blks=128, version=000000000000) [05,sd05] itm: part1(start=320, blks=128, version=201710271804), part2(start=320 , blks=128, version=000000000000) [06,sd06] boot: part1(start=448, blks=24, version=201710271804), part2(start=448 , blks=24, version=000000000000) [07,sd07] tzk_normal: part1(start=472, blks=8, version=201710271804), part2(star t=472, blks=8, version=000000000000) [08,sd08] system: part1(start=480, blks=1600, version=201710271804), part2(start =480, blks=1600, version=000000000000) [09,sd09] user_setting: part1(start=2080, blks=960, version=201710271804), part2 (start=2080, blks=960, version=000000000000) [10,sd10] cache: part1(start=3040, blks=896, version=201710271804), part2(start= 3040, blks=896, version=000000000000) [11,sd11] firmware: part1(start=3936, blks=64, version=201710271804), part2(star t=3936, blks=64, version=000000000000) [12,sd12] factory_data: part1(start=4000, blks=32, version=201710271804), part2( start=4000, blks=32, version=000000000000) [13,sd13] userdata: part1(start=4032, blks=3328, version=201710271804), part2(st art=4032, blks=3328, version=000000000000) get macaddr from fts: cpu id:38bdc6b3 5359eb9c macaddr=00:B3:53:59:EB:9C tzk boot with normal mode start to kick off SM CPU: start 0x3ff0449c, size 63216 SM CPU is kicked [ of f . L 1as]It(pSoMwe)r:m eondte eirs mnaoint St[a nd b y 6]W(SM): Entering adc_init. [ 10]W(SM): Leaving adc_init. [ 13]W(SM): PWM Initialized [ 16]I(SM): begin to run tasks [ 509]W(SM): Joystick connected [3.019337] TZ CPU0 ERROR[tz_sw_verify_image:75] verify image fail, src=0x19c0000 0, len=0x004c0c00, dst=0x19c00000GIH magic num is not correct (0x482a4d49 != 0xe ea8f2bc)!!! FATAL ERROR! There is no bootable image on this machine! tbdzz---- Img_Ld_And_Start error! Spinning now! œëYS³Æ½8[ 0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state =0x0 [ 278] image verified, start at 0x00920000... tz kernel starting... MV88DE3114(BG2Q)-A1 total 4 cpus, v2.0.0.21, Aug 5 2014 1 4:39:52 0321[ 333] start_bootloader UªULAUNCH_ITM is set to zero board_number = 6 uiBoot = 0 I2C switch set as 0
cosa ne pensate?
Modificato: da Alschepmist
