abbio90 Inserito: 17 giugno 2019 Segnala Inserito: 17 giugno 2019 Ciao a tutti...ho una RB con balance pcc in cui ho ISP1 wisp locale e ISP2 sim ho.mobile ho impostato queste regole /ip firewall nat add action=masquerade chain=srcnat comment="Masquerade WAN" out-interface="ether5 WAN FLYNTER" add action=masquerade chain=srcnat out-interface=lte1 /ip firewall mangle add action=accept chain=prerouting dst-address=192.168.1.1 in-interface="BRIDGE LAN" add action=accept chain=prerouting dst-address=192.168.159.1 in-interface="BRIDGE LAN" add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=lte1 new-connection-mark=ISP_ho \ passthrough=yes add action=mark-connection chain=prerouting connection-mark=no-mark in-interface="ether5 WAN FLYNTER" \ new-connection-mark=ISP_fly passthrough=yes add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface="BRIDGE LAN" \ new-connection-mark=ISP1_ho-conn passthrough=yes per-connection-classifier=both-addresses:2/0 add action=mark-connection chain=prerouting connection-mark=no-mark dst-address-type=!local in-interface="BRIDGE LAN" \ new-connection-mark=ISP2_fly-conn passthrough=yes per-connection-classifier=both-addresses:2/1 add action=mark-routing chain=prerouting connection-mark=ISP1_ho-conn in-interface="BRIDGE LAN" new-routing-mark=\ to_ISP-ho passthrough=yes add action=mark-routing chain=prerouting connection-mark=ISP2_fly-conn in-interface="BRIDGE LAN" new-routing-mark=\ to_ISP-fly passthrough=yes add action=mark-routing chain=output connection-mark=ISP1_ho-conn new-routing-mark=to_ISP-ho passthrough=yes add action=mark-routing chain=output connection-mark=ISP2_fly-conn new-routing-mark=to_ISP-fly passthrough=yes /ip route add check-gateway=ping distance=1 gateway=8.8.4.4 routing-mark=to_ISP-ho target-scope=30 add check-gateway=ping comment="WAN FLYNTER" distance=1 gateway=8.8.8.8 routing-mark=to_ISP-fly target-scope=30 add check-gateway=ping distance=1 gateway=8.8.4.4 target-scope=30 add check-gateway=ping distance=2 gateway=8.8.8.8 target-scope=30 add distance=1 dst-address=8.8.4.4/32 gateway=192.168.1.1 add distance=1 dst-address=8.8.8.8/32 gateway=192.168.159.1 pare che spesso esempio da pc portatile se lancio lo speed test rileva l'ip dell'isp2 e usa la banda dell'isp1 o viceversa.. inoltre a questo device c'è un vpn server che per farlo andare devo disabilitare ISP2 (LTE) qualcuno sa aiutarmi?
