claudio.macciocchi Inserito: 27 giugno 2019 Segnala Inserito: 27 giugno 2019 Buonasera, cortesemente qualcuno mi puo dire come siprogramma la ricevente :Ktnn-2202a. Grazie
claudio.macciocchi Inserita: 28 giugno 2019 Autore Segnala Inserita: 28 giugno 2019 14 ore fa, claudio.macciocchi scrisse: Buonasera, cortesemente qualcuno mi puo dire come siprogramma la ricevente :Ktnn-2202a. Grazie Aggiungo il nome piu precisamente il nome della ricevente:KTNN-KG2202-A
Lorenzo-53 Inserita: 28 giugno 2019 Segnala Inserita: 28 giugno 2019 1, Jog/Momentary function learning method: Press the “Learning PaBuon” on the receiving board once and the LED lights up. Release the “Learning PaBuon” to enter the learning code mode. Press the remote control A buon, the LED flashes 3 times, and then press the remote control B The key, the LED flashes 3 times, which means that the pais successful and the system automatically exits the learning mode. If there is no remote control signal after entering the learning code mode, the learning code mode will be automatically exited after 10 seconds. 2, Self-locking/Toggle function learning method: Press the "" learning pabuon" on the receiver board twice, the LED lights up, release the "learning pabuon", enter the learning code mode, press the remote control A buon, the LED flashes 3 times, and then press the remote control Buon B, LED flashes 3 times, which means that the is successful, the system automatically exits the learning mode.If you enter the learning code mode, there is no remote control signal, after 10 seconds, automatically exit the learning code mode. 3, Interlock//Latched function learning method: Press the “Learning PaBuon” on the receiving board three times, the LED lights up, release the “Learning PaBuon”, enter the learning code mode, press the remote control A buon, the LED flashes 3 times, and then press the remote control B The key, the LED flashes 3 times, means the is successful, the system exits the learning mode automatically. If there is no remote control signal after entering the learning code mode, the learning code mode will be automatically exited after 10 seconds. Clear data: Press the "Learning PaBuon" for 8 consecutive times. The LED indicator flashes 8 times. Then the clear code is completed and all remote control key codes learned before are cleared. Output mode explanation: 1. Self-locking: Press the same remote control buon, press, relay opens, press again, relay off. 2. Jog: press the remote control “A” key, the relay opens, release the remote control “A” key, the relay is off. If you keep pressing the "A" buon on the remote control, the relay will remain on. When you release the remote control, the relay will turn off. 3, interlock: Press the remote control "A" buon, the relay opens, press the remote control "B" buon, the relay off. Precautions: 1. Do not operate with electricity. Turn off the power and operate it. Check the power supply after use. 2. When the voltage of the remote controller is insufficient, please change the baery in time (when the remote controller baery voltage is insufficient, the general remote control distance becomes close). 3. When using wireless electronic products, care should be taken to avoid metal masks, large electronic devices, electromagnetic fields, etc., which have a strong source of interference, to avoid the remote control and the receiving distance being short or unable to work properly. 4. Do not use this electronic product abnormally. Unusual use will reduce product performance and longevity. In severe cases, damage to the product will also bring hidden dangers to your safety.
Livio Orsini Inserita: 29 giugno 2019 Segnala Inserita: 29 giugno 2019 (modificato) Claudio.Maciocchi è inutile quotare l'intero messaggio senza aggiungere altro . Ho tolto il messaggio perchè inutile e toglie comprensibilità alla discussione. Modificato: 30 giugno 2019 da Livio Orsini
claudio.macciocchi Inserita: 6 luglio 2019 Autore Segnala Inserita: 6 luglio 2019 Chiedo scusa e ringrazio dell'aiuto.
