hello,
i have problem in using AT82 ariston washing machine. is there any manual available? i wanna know hot to reduce the time of washing and what is appropriate foe washing ordinary clothes
Hello!
Did you try to search the manual on the Hotpoint site? I see that in the Italian version of that site there is a copy of the manual, but it's obviously wrote in Italian language…
I'm not familiar with that washing machine, but washing time can be normally influenced by setting low water temperatures and/or too high doses of detergent. Furthermore, if the washing machine "perceive" that the load is unbalanced, it could extend the time of the spin cycle a lot
In order to suggest you the right program for your clothes, we should know which kind of clothes they are. The better thing to do is to read the clothes labels and set the washing machine accordingly. For example, resistant cotton tablecloths can be usually washed by setting the program #3 at 60 °C, synthetic clothes can be washed  by setting the programs #6 or #7, wood clothes can be washed with the program #9 and silk clothes can be washed with the program #10
Since "Quotidiano" means "Daily", the program #8 should be a sort of "jolly"
HTH
Modificato: da UABC80
