keremcelenn Inserito: 3 giugno 2021 Segnala Inserito: 3 giugno 2021 Hello, I'm thinking of doing image processing with a Python application and sending the result to plc and making operations on the conveyor belt. For example, if the object color is red, it is pushed to the 1st box by the drive motor. The connection between PLC and PC is provided with the . of Siemens MPI Adapter. My PLC does not have an ethernet port. What kind of library should I use between a wired PLC and Python? Thanks.
