Inserito: (modificato)
Hello everybody. I hope I did not make a mistake with the topic.
This module controls danfoss vlt302 via analog input 0-10v.
The problem is that the output voltage is 85mV.  When I disconnect the external
power supply of the module, the voltage disappears.
Replacing the external power supply did not ., replacing the module
did not . either. Maybe someone has encountered something similar?
Modificato: da Oleksandr333
