gascan Inserito: 22 novembre 2004 Segnala Inserito: 22 novembre 2004 Hi, there, I'm looking for an example of program for omron cqm1 and gsm modem to send sms text messages.Where can I find it?thanks and regards from spain
FaxPLC Inserita: 23 novembre 2004 Segnala Inserita: 23 novembre 2004 Hello, maybe you can find this on the section "Up/download file" but you must make a new registration in that section.I'm sorry for my english.With Omron you can use the instructions RXD and TXD for send and receive the AT command in RS232.Is more important to configure the RS232 port correctly with sistems memory.ByeFaby.
gascan Inserita: 23 novembre 2004 Autore Segnala Inserita: 23 novembre 2004 thanks for your answer, I look for the sections of download and I didn't find it, I only find one example for CJ1 and there is some diferences between the plcs.
FaxPLC Inserita: 24 novembre 2004 Segnala Inserita: 24 novembre 2004 Hello, I have used a modem FALCOM with a CQM1H in order to send and receive SMS.If you do not know the modem GSM and the CQM1 you can:1) Find the handbook of the PLC and your modem. 2) Test SMS AT COMMAND with a software PC (Hyperterminal). 3) To use functions [at]RXD and [at]TXD in order to send the AT Command from the PLC. If you do not know to them you see on the handbook. If you meet problems you write to us. If you want, you call your local omron office. The technicians are available to give technical support.Bye See you next time! Faby.
gascan Inserita: 24 novembre 2004 Autore Segnala Inserita: 24 novembre 2004 okithanks, I try to study the these functionsbye
