Gullit1967 Inserito: 1 novembre 2024 Segnala Inserito: 1 novembre 2024 hi to everybody, i would know one think about this cpu if is possible...i have one project into the machine what i've tryed,..i made some modification on the logic and then at the end of my work i try to save the project with the date, before to do that every things it was ok every led on the software was green for hardware and software...for example the name of the project it's this one " job23111+T4058 V17 " (same name on hardware)...i select project menù then i select " save as " and i write " job23111+T4058 V17_301024 " ...the next day when i come back to work i go online with a plc and i see the led blue/orange on the hardware cpu, like if you have some difference...the logic it's ok just the hardware cpu have this problem and i dont understand why...maybe it's 'cause the name on cpu is univocal or absolute on the hardware ? somebody know why ? thank's a lot in advance
drn5 Inserita: 1 novembre 2024 Segnala Inserita: 1 novembre 2024 (modificato) Potrebbe essere una differenza di Firmware tra online e offline. Mi sono trovato in alcuni casi in una situazione simile, come se la cpu non riuscisse a caricare il firmware quando carichi il progetto. Ma nel Online & diagnostic dovresti avere qualche informazione in più... P.S. accade la stessa cosa con i pannelli, metti la spunta su FIT, ma nonostante aggiorni al caricamento successivo lo richiede ancora, ancora e ancora. Modificato: 1 novembre 2024 da drn5
Gullit1967 Inserita: 2 novembre 2024 Autore Segnala Inserita: 2 novembre 2024 ok i'll try to check it...thanks a lot
