dvx70 Inserito: 3 febbraio 2005 Segnala Share Inserito: 3 febbraio 2005 Qualcuno potrebbe dirmi quali sono le funzionalità di tutti i dip switches del CJ1M.So che il 2 attiva la memory card, il 4 attiva il Sysmac Way, ma gli altri ?Ho cercato sul manuale della CPU e su quello di programmazione, ma non ho trovato nulla.Grazie in anticipo. Link al commento Condividi su altri siti More sharing options...
luigi spotti Inserita: 3 febbraio 2005 Segnala Share Inserita: 3 febbraio 2005 Pin Function Setting Description1 Write-protection foruser programmemory (UM) (See note 1.)ON Write-protected User program memory is write-protected when this pin is ON.Turn ON to prevent the program from being changed accidentally.OFF Read/write2 Automatic transferof the program atstart-upON Yes The program (AUTOEXEC.OBJ) and PC Setup(AUTOEXEC.STD) will be transferred from the Memory Card tothe CPU Unit automatically at start-up when this pin is ON. (Seenote 4.)A PC’s software (program and PC Setup) can be completely initializedjust by inserting a new Memory Card and turning on thepower. This can be used to switch the system to a new arrangementvery quickly.Note When pin 7 is ON and pin 8 is OFF, reading from theMemory Card for easy backup is given priority; even if pin2 is ON, the program will not be automaticallytransferred.OFF No3 Not used. --- --- ---4 Peripheral portcommunicationsparametersON Use parametersset in the PCSetup.• Leave this pin OFF when using a Programming Console orCX-Programmer (peripheral bus setting) connected to theperipheral port.• Turn this pin ON when the peripheral port is being used for adevice other than a Programming Console or CX-Programmer(peripheral bus setting).OFF(default)Auto-detect ProgrammingDevice(See note 2.)5 RS-232C port communicationsparametersON Auto-detect ProgrammingDevice(See note 3.)• Leave this pin OFF when the RS-232C port is being used fora device other CX-Programmer (peripheral bus setting) suchas a Programmable Terminal or host computer.• Turn this pin ON when using CX-Programmer (peripheral bussetting) connected to the RS-232C port. OFF(default)Use parametersset in the PCSetup.6 User-defined pin ON A39512 ON The ON/OFF status of this pin is reflected in A39512. Use thisfunction when you want to create an Always-ON or Always-OFFcondition in the program without using an Input Unit.OFF(default)A39512 OFF7 Easy backup settingON Writing from theCPU Unit to theMemory CardPress and hold the Memory Card Power Supply Switch for threeseconds.Restoring fromthe MemoryCard to the CPUUnit.To read from the Memory Card to the CPU Unit, turn ON the PCpower.This operation is given priority over automatic transfer (pin 2 isON) when power is ON.7 Easy backup settingOFF(default)Verifyingcontents ofMemory Card.Press and hold the Memory Card Power Supply Switch for threeseconds.8 Not used OFF(default)Always OFF.ciao Link al commento Condividi su altri siti More sharing options...
