emsina Inserito: 11 luglio 2011 Segnala Inserito: 11 luglio 2011 (modificato) SALVE A TT HO UN CONDIZIONATORE SAMSUNG AQV12M ACQUISTATO 3 ANNI FA E QNDI FUORI GARANZIA... L'HO ACCESO DOPO L'INTERO INVERNO SPENTO E MI APPARE SUL DISPLAY E4 71 .... NON VORREI PROPRIO DARE 40,00 € + IVA AL TECNICO SAMSUNG OLTRE ALLA RIPARAZIONE. QLKN SA AIUTARMI STAMATTINA HO KIAMATO UN ALTRO TECNICO AMICO E MI HA DETTO che LA LISTA DEI CODICI DI ANOMALIA LI HA SAMSUNG ....SE FOSSI RIUSCITA A RISALIRCI AVREBBE POTUTO AIUTARMI. CONFIDO IN VOI GRAZIE! Modificato: 11 luglio 2011 da Luca Bettinelli evitare di scrivere tutto in maiuscolo, GRAZIE
stivano Inserita: 11 luglio 2011 Segnala Inserita: 11 luglio 2011 Inverter Unit SamsungDisplay = E1 01Explanation and Checking points = Communication error (indoor unit unable to receive data) - Check cablesDisplay = E1 02Explanation and Checking points = Communication error (outdoor unit unable to communicate) - Check addressesDisplay = E1 21Explanation and Checking points = Indoor unit room temperature sensor error (Open/Short) - Check and replace if requiredDisplay = E1 22Explanation and Checking points = Indoor unit sensor error - Evaporator pipe in sensor error (Open/Short) - Check and replace if requiredDisplay = E1 23Explanation and Checking points = Indoor unit sensor error - Evaporator pipe out sensor error (Open/Short) - Check and replace if requiredDisplay = E1 28Explanation and Checking points = Indoor unit sensor error - Evaporator pipe out sensor detachedDisplay = E1 30Explanation and Checking points = Indoor unit heat exchanger in & out temperature sensor detachedDisplay = E1 54Explanation and Checking points = Indoor unit fan malfunctionDisplay = E1 61Explanation and Checking points = More than 2 indoor units cool and heat simultaneouslyDisplay = E1 62Explanation and Checking points = EPROM errorDisplay = E1 63Explanation and Checking points = Option code setting errorDisplay = E1 85Explanation and Checking points = Cable miss wiringDisplay = E2 01Explanation and Checking points = The number of indoor unit mismatchedDisplay = E2 02Explanation and Checking points = Communication error (outdoor unable to receive data)Display = E2 03Explanation and Checking points = Communication error between two microcontroller on the outdoor PCBDisplay = E2 21Explanation and Checking points = Outdoor temperature sensor error (Short/Open) - Check and replace if requiredDisplay = E2 37Explanation and Checking points = Condenser temperature sensor error (Short/Open) - Check and replace if requiredDisplay = E2 46Explanation and Checking points = Condenser temperature sensor detachedDisplay = E2 51Explanation and Checking points = Compressor discharge sensor error (Short/Open) - Check and replace if requiredDisplay = E2 59Explanation and Checking points = Outdoor unit errorDisplay = E2 60Explanation and Checking points = Compressor discharge sensor error (Short/Open) - Check and replace if requiredDisplay = E2 61Explanation and Checking points = Compressor discharge sensor detachedDisplay = E3 20Explanation and Checking points = Compressor OLP sensor error (Short/Open) - Check and replace if requiredDisplay = E4 01Explanation and Checking points = Indoor unit heat exchanger freezing and compressor stop (cooling mode)Display = E4 04Explanation and Checking points = Outdoor unit overload and compressor stop (protection control in heating mode)Display = E4 16Explanation and Checking points = Outdoor unit high discharge temperature and compressor stop (heating mode)Display = E4 19Explanation and Checking points = Outdoor unit EEV open error (self diagnosis) - Check and replace if requiredDisplay = E4 22Explanation and Checking points = Outdoor unit EEV close error (self diagnosis) - Check and replace if requiredDisplay = E4 40Explanation and Checking points = High temperature (over 30°C) of outdoor as heating modeDisplay = E4 41Explanation and Checking points = Low temperature (under -5°C) of indoor as cooling modeDisplay = E4 58Explanation and Checking points = error fanDisplay = E4 60Explanation and Checking points = Wrong connection between communication and power cableDisplay = E4 61Explanation and Checking points = Inverter compressor starting failure (5 times)Display = E4 62Explanation and Checking points = Compressor trip by input current limit controlDisplay = E4 63Explanation and Checking points = Compressor trip by OLP temperature limit controlDisplay = E4 64Explanation and Checking points = Compressor peak current protectionDisplay = E4 65Explanation and Checking points = Compressor overload protection by currentDisplay = E4 66Explanation and Checking points = DC-link voltage error (under 150V or over 410V)Display = E4 67Explanation and Checking points = Compressor rotation errorDisplay = E4 68Explanation and Checking points = Current sensor error - Check and replace if requiredDisplay = E4 69Explanation and Checking points = DC-link voltage sensor error - Check and replace if requiredDisplay = E4 70Explanation and Checking points = Compressor overload protection - Check refrigerant charge and heat exchangersDisplay = E4 71Explanation and Checking points = EPROM error - Check and replace PCB if requiredDisplay = E4 72Explanation and Checking points = AC line zero-crossing detection circuit error - Check power supplyDisplay = E5 54Explanation and Checking points = No refrigerant error (self diagnosis) - Check refrigerant charge
aiutante Inserita: 11 luglio 2011 Segnala Inserita: 11 luglio 2011 (modificato) Ottimo. Modificato: 11 luglio 2011 da Luca Bettinelli
emsina Inserita: 11 luglio 2011 Autore Segnala Inserita: 11 luglio 2011 (modificato) grazie mille!! qndi (=quindi) secondo voi posso dirlo ad un tecnico anche se non è autorizzato samsung? c'è da cambiare la scheda? a qnto (=quanto) ho capito...**regolamentoj) Divieto d'usare le K al posto di CH o C (perkè, cosa...), non come non, xche' come perché, x come per........... Modificato: 12 luglio 2011 da Livio Migliaresi
reka Inserita: 12 luglio 2011 Segnala Inserita: 12 luglio 2011 guarda, magari c'è qualche procedura di reset o altro.speriamo che l'amico dei codici sia così gentile da dircelo direi intanto di sentirlo il tecnico, magari s'intende un po' di schede è può controllare.
