fab.nippo Inserito: 14 ottobre 2011 Segnala Inserito: 14 ottobre 2011 Buongiorno a tutti!Qualcuno potrebbe chiarirmi il significato di questa istruzione:ASM KH 1F5CE' dentro un FB protetto.Grazie mille a tutti
Lucky67 Inserita: 14 ottobre 2011 Segnala Inserita: 14 ottobre 2011 The asm instruction is followed by ju=m001 then beif you use a hex editor (if you can find the block) & change the be to nop1 then the code becomes readable as mc5 however it probably does not make much sense.a lot of blocks you mentioned are for communications 525,535 & others for special function cards.Some standard function blocks include the instruction ASM which is 'switch to ASSEMBLER operation'.Although the programming unit may interpret and display subsequent data as STEP5 instructions, they should be disregarded since the raw data is assembler data and not MC5.Standard function blocks are identified by a Library number starting with 'P71200..' and are best regarded as 'black boxes'.
fab.nippo Inserita: 14 ottobre 2011 Autore Segnala Inserita: 14 ottobre 2011 Grazie mille, mi hai chiarito un pò le idee...
