Visual And Keyboard Logo! Expansion?
Hi to all,
Sorry to use English language but only I can speak and read Italian right (more or less :( ).
I'm a newbie in PLCs and I like to begin with LOGO! but I have a trouble:
- Are there any posibility to use LOGO!basic and/or LOGO!pure CPUs connected to a TD200 even a TP070 or similar evn not Siemens branded?
Thanks in advance,
Hi Breixo, excuse me for my English, but I'm not a Teacher!!!
There isn't possibilities to connect Logo! with TD 200 or TP 070, but Logo! have a little display on board that you can use to read internal program and state of I/0.
If you want connect TD 200 or TP 070 you must buy a little plc (s7 200),there is little CPU as some as CPU 221,there are very chip... :huh::huh::huh: (165 Euro for S7 200 True Power Box) . Good Luck
Whit LOGO 4 (attention logo with xxx-xxx 0AB4 and not xxx-xxx 0AB3 code ) and software logo confort V4.0 ...
u can use about 10 txt display messages ... with internal variable ( Timer, Counter ;) 4 ex)
This LOGO 4 have a (little :D ) backlight display, is 10 time more quickly and u can use more than 100 instruction !!!
Nel caso avessi scritto stup.... :P lo scrivo anche in italiano :unsure:
Il logo4 ( quello con codice finale 0AB4 e non 0AB3 son tutti e due logo4 attenzione) e sw logo confort V4.0
Si possono usare circa (non ricordo ora bene) 10 messaggi di testo con variabili interne.
Il logo4 0AB4 è retroilluminato :o , è 10 volte più veloce e può contenere oltre 100 istruzioni !!!
Bye ... ciao !
