Uso da tempo il parsic, ma ho notato una limitazione, se voglio far suonare un buzer passivo collegandolo al pic, riesco a farlo cantare ad un max di soli 50hz (2ms) che è la max frequenza data da parsic sul modulo clock.
Penso però che si possa modificare la frequenza modificando l'asm.
Sotto allego appunto l'asm ricavato da parsic per 16f84 con 50hz di uscita su rb.0.
Se per esempio volessi portare la frequenza a 3khz, che valori dovrei toccare?
; Source created with Parsic Version 3.x
; at              : 08/05/05 13.09.09
; Project File    : C:\PROGRA~1\PARSIC~1\BOZZE\p.PIC
; Project Version : 1.0.0
; Created         : 08/05/05 13.08.16
; Last change     : 08/05/05 13.09.01
    PROCESSOR 16F84
    INCLUDE P16F84.INC
    RADIX DEC
    __IDLOCS H'0100'
    __CONFIG _CP_OFF & _PWRTE_OFF & _WDT_ON & _XT_OSC
; Diverses
ZERO    EQU Z; ZERO-Flag
CARRY  EQU C; CARRY-Flag
; Variable
SYS_WSAV    = 12; located in Bank 0, 1
SYS_SSAV    = 13; located in Bank 0, 1
TR1    = 14; located in Bank 0, 1
TR1_HI    = 15; located in Bank 0, 1
RAM    = 16; located in Bank 0, 1
    ERRORLEVEL -302; disable warning (Bankswitching)
    ERRORLEVEL -306; disable warning (Pageswitching)
;Programmanfang
    ORG 0
    CLRF STATUS; switch to RAM-Bank 0
    GOTO SYS_INIT
    NOP
    NOP
;Interrupt-Adress
    MOVWF SYS_WSAV; save register
    SWAPF STATUS,W
    CLRF STATUS; bank 0
    MOVWF SYS_SSAV
    BCF INTCON,T0IF; Interrupt quitieren
    INCFSZ TR1,F
    GOTO SYS_INT_LABEL_0
    INCF TR1_HI,F
SYS_INT_LABEL_0
EXITINT
    SWAPF SYS_SSAV,W; Register zurück
    MOVWF STATUS
    SWAPF SYS_WSAV,F
    SWAPF SYS_WSAV,W
    RETFIE
; Subroutines
;Initialisierung
SYS_INIT
    MOVLW B'00100000'
    MOVWF INTCON
; Set output before direction
    BCF STATUS,RP0; Bank 0
    MOVLW B'00000000'
    MOVWF PORTA
    MOVLW B'00000000'
    MOVWF PORTB
    MOVLW 143
    BSF STATUS,RP0; Bank 1
    MOVWF OPTION_REG
; Richtung setzen
    MOVLW B'11111111'
    MOVWF TRISA
    MOVLW B'11111110'
    MOVWF TRISB
; init vars
; Clear RAM
    MOVLW 12
    MOVWF FSR
CR1
    CLRF INDF
    INCF FSR,F
    MOVFW FSR
    SUBLW 80
    BTFSS STATUS,ZERO
    GOTO CR1
    CLRF TMR0
    BCF INTCON,T0IF
    BSF INTCON,GIE; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
    CLRWDT
; Timer -> TR1
    MOVLW 0; Test auf >=
    SUBWF TR1_HI,W;F-W -> W
    BTFSS STATUS,ZERO
    GOTO LABEL_TR1_CHECK
    MOVLW 4
    SUBWF TR1,W;F-W -> W
LABEL_TR1_CHECK
    BTFSS STATUS,CARRY
    GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
    SUBWF TR1_HI,F;F-W -> F
    MOVLW 4
    SUBWF TR1,F;F-W -> F
    BTFSS STATUS,CARRY
    DECF TR1_HI,F
LABEL_TR1_SET; toggel output
    BTFSC PORTB,0
    GOTO LABEL_TR1_CLR
    BSF PORTB,0
    GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
    BCF PORTB,0
LABEL_TR1_ENDE
    GOTO MAIN
    END
