aduri Inserito: 17 luglio 2007 Segnala Share Inserito: 17 luglio 2007 (modificato) Ho provato, per la prima volta, a vedere come funziona il convertitore A/D del pic16f877a ed ha funzionato alla prima ma ho provato ad apportare delle modifiche al codice MKB per avere la possibilita' di conversioni multiple ma non ha funzionato o per meglio dire funziona solo un canale e l'altro segue molto disturbato i valori del primo.Il mio dubbio e' anche capire MKB cosa fa con i registri intco1 e intcon0 quando usa la macro ADC_read(2).Qualcuno ha esperienze a proposito?Allego il listato: program adc2_lcd'(*' * Project name:' adconlcd' * Copyright:' © mikroElektronika, 2005 - 2006' * Revision History:' 20050312:' - initial release.' * Description:' This code demonstrates how to use library function ADC_read, and library' procedures and functions for LCD display (4 bit interface)' * Test configuration:' MCU: PIC16F877A' Dev.Board:' Oscillator: HS, 4.000 MHz' Ext. Modules: None' SW: mikroBasic v5.0 or higher' * NOTES:' - If you are using EasyPIC4, use provided jumper on top right to connect potentiometer to RA2' *)dim ch1 as byte ch2 as byte t1 as word t2 as word Text1 as char[17] Text2 as char[17] tlong1 as longint tlong2 as longintmain: PORTB =0 ' clear portb TRISB =0 ' designate portb as output (LCD is connected to portb) intcon =0 ' disable all interrupts Lcd_Init(PORTB) ' initialize (4-bit interface connection) Lcd_Cmd( LCD_CURSOR_OFF) ' send command to LCD (cursor off) Lcd_Cmd(LCD_CLEAR) ' send command to LCD (clear LCD) Text1 ="A/D Aduri" ' assign text to string a Lcd_Out(1,1, Text1) ' print string a on LCD, 1st row, 1st column Text2 ="Prova" ' assign text to string a Lcd_Out(2,1, Text2) ' print string a on LCD, 2nd row, 1st column OPTION_REG = $80 ADCON1 = $82 ' configure VDD as Vref, and analog channels TRISA = $FF ' designate porta as input Delay_ms(2000) Text1 = "voltage1:" ' assign text to string a Lcd_Out(1,1,Text1) ' print string a on LCD, 2nd row, 1st column Lcd_Chr(1,14,"V") Text2 = "voltage2:" ' assign text to string a Lcd_Out(2,1,Text2) ' print string a on LCD, 2nd row, 1st column Lcd_Chr(2,14,"V") while true t1 = ADC_read(1) ' get ADC value from 1st channel tlong1 = t1*5000 t1 = tlong1 >> 10 ch1 = t1 div 1000 ' prepare value for diplay Lcd_Chr(1,11,48+ch1) ' write ASCII at first row, 9th column Lcd_Chr(1,12,".") ch1 = (t1 div 100) mod 10 Lcd_Chr(1,13,48+ch1) ch1 = (t1 div 10) mod 10 Lcd_Chr(1,14,48+ch1) ch1 = t1 mod 10 Lcd_Chr(1,15,48+ch1) delay_ms(1) t2 = ADC_read(2) ' get ADC value from 2nd channel tlong2 = t2*5000 t2 = tlong2 >> 10 ch2 = t2 div 1000 ' prepare value for diplay Lcd_Chr(2,11,48+ch2) ' write ASCII at 2nd row, 9th column Lcd_Chr(2,12,".") ch2 = (t2 div 100) mod 10 Lcd_Chr(2,13,48+ch2) ch2 = (t2 div 10) mod 10 Lcd_Chr(2,14,48+ch2) ch2 = t2 mod 10 Lcd_Chr(2,15,48+ch2) delay_ms(1) wendend. Cordiali saluti Modificato: 17 luglio 2007 da aduri Link al commento Condividi su altri siti More sharing options...
aduri Inserita: 25 luglio 2007 Autore Segnala Share Inserita: 25 luglio 2007 Sono riuscito a risolvere e funziona.Non avevo letto bene il datasheet che limitava il valore dell'impedenza d'ingresso, ho sostituito i trimmer con valori piu' bassi ed ha funzionato perfettamente.Spero che questo post possa servire ad altri per non commettere il mio stesso errore. Link al commento Condividi su altri siti More sharing options...
rob10kg Inserita: 28 luglio 2007 Segnala Share Inserita: 28 luglio 2007 Ciao Aduri l'hai steso tu il codice oppure è un sample fornito dalla Microchip?Se l'hai steso tu complimenti.Mi piacerebbe imparare.Ciao. Link al commento Condividi su altri siti More sharing options...
aduri Inserita: 29 luglio 2007 Autore Segnala Share Inserita: 29 luglio 2007 Mi spiace deluderti ma e' un esempio di mikrobasic modificato per le mie esigenze. A/D su piu' canali l'originale era su un solo canale.Ciao Link al commento Condividi su altri siti More sharing options...
