Pic 16f57 Con Picstart Plu - non riesco a programmare 16f57 con picst
Salve. Ho un problema. Non riesco a programmare il PIC 16f57 con il Picstart Plus nonostante sia stato aggiornato con il kit di aggiornamento e vi sia stato caricato il firmware " pspsl 44001.hex "tramite il menu a tendina "PROGRAMMER" "DAWNLOAD PICSTART OS" di MPLAB IDE 8.46 che ho in uso.
Precisamente, la programmazione avanza molto lentamente e al termine mi compare il seguente messaggio:
PICSTART Plus Firmware Version 04.40.01Erase operation is successful.
PICSTART Program\Verify Report
10-Mar-2010, 21:53:20
Device Type: PIC16F57
Address Range 0-3c6
Program Memory Errors
Non so cosa possa aver frainteso o dimenticato.
Per favore, qualcuno mi può dare qualche dritta?
Grazie.
Giuseppe
9. Programming PIC16C55A/C57C/F57 Devices
From ETN #22:
Symptom: PIC16C55A, PIC16C57C and PIC16F57 devices do not verify correctly
using the PICSTART Plus. When a blank device is read, program memory
values of 0xBFF are reported.
Problem: The OSC2 pin on the PIC16C55A, PIC16C57C and 16F57 tries to
overdrive RB6. This causes invalid voltage levels for verification.
Solution: To program the PIC16C55A, PIC16C57C and the 16F57 in DIP
packages on a PICSTART Plus, a modified adapter must be used. The
adapter can be created using a 28- or 40-pin ZIF, LIF or standard
socket by cutting the connector pin that corresponds to pin 26 the
device. After creating this modified adapter, secure the device in
the adapter, then place the modified adapter in the PICSTART Plus.
This adapter should only be used when programming these devices.
