Problema Di Traduzione Lingua
#Andrea#
ciao a tutti ho un problema sulla traduzione del software di un apparecchiatura acquistata non riesco a capire in che linguaggio di programmazione si scritto allego un estratto.
<!--Usb.c-->
<P id="USB_SelAxis_00" len="2">(选轴)</P>
</strings>
</resource>
<P id="MESURE_Layer2_caption1_00" len="64">(Basic)</P>
<P id="MESURE_Layer2_caption1_01" len="64">(Figure)</P>
<P id="MESURE_Content_00_00" len="64">(PCD)</P>
<P id="MESURE_Content_00_01" len="64">(Oblique Line drilling)</P>
<P id="MESURE_Content_00_02" len="64">(Array Hole drilling)</P>
<P id="MESURE_Content_00_03" len="64">(Chambering)</P>
<P id="MESURE_Content_00_04" len="64">(Tool compensate)</P>
<P id="MESURE_Content_00_05" len="64">(Incline machining)</P>
<P id="MESURE_Content_00_06" len="64">(Smooth R)</P>
<P id="MESURE_Content_00_07" len="64">(Simple R)</P>
<P id="MESURE_Content_01_00" len="64">(PCD)</P>
<P id="MESURE_Content_01_01" len="64">(Oblique Line drilling)</P>
<P id="MESURE_Content_01_02" len="64">(Chambering)</P>
<P id="MESURE_Content_02_00" len="64">(Edit Tool data base)</P>
<P id="MESURE_Content_02_01" len="64">(Use Tool)</P>
<P id="MESURE_Content_02_02" len="64">(Taper measure)</P>
<P id="MESURE_Content_02_03" len="64">(Constant rate cutting)</P>
<P id="MESURE_Content_02_04" len="64">(Edit element)</P>
<P id="MESURE_Content_02_05" len="64">(Complex machining)</P>
<P id="MESURE_Content_03_00" len="64">(Debouncing )</P>
<P id="MESURE_Content_04_00" len="64">(EDM )</P>
<P id="MESURE_Content_04_01" len="64">(PCD )</P>
<P id="MESURE_Content_05_00" len="64">(Equality )</P>
<P id="MESURE_Content_05_01" len="64">(Universal )</P>
<P id="MESURE_Content_05_02" len="64">(Slot Para )</P>
<P id="MESURE_Content_06_00" len="64">(Base Pos )</P>
se avete un idea di che tipo di linguaggio programmazione sia vi ringrazio
Link al commento
Condividi su altri siti
Molto probabilmente è XML (eXtensible Markup Language); una estensione decisamente migliore di HTML.
Si dovrebbe capire dalle prime righe del programma.
Cioa.
Link al commento
Grazie nel frattempo sono riucito a capire che che questa apparecchiatura è collegabile al pc trammita una usb ma collegandola a windows mi chiedermi i driver "SamArm DVK" qualcuno sa dove trovarli?
Link al commento
