Cavo Usb 8 Metri
giuseppegerax
Salve ragazzi, sono qui per chiedervi un suggerimento. Avrei bisogno di un cavo usb lungo 8 mt. Inoltre, questo cavo, dovrebbe passare in un condotto stretto dove non entrerebbe il connettore USB, avrei quindi bisogno di tagliare il connettore e poi risaldarlo. Alla luce di tutte queste problematiche, mi erano venute in mente due idee:
1) tagliare cavo usb, farlo passare dentro il condotto, risaldare connettore e collegare i due cavi usb (di cui uno sarebbe solamente una semplice prolunga) attraverso un ripetitore di segnale
2) utilizzare una soluzione usb-ethernet-usb con relativi convertitori.
Quale mi consigliate delle due?
Grazie in anticipo.
preso da qui
Cabling
magnify-clip.pngA USB twisted pair, where the "Data +" and "Data −" conductors are twisted together in a double helix. The wires are enclosed in a further layer of shielding.
The data cables for USB 1.x and USB 2.x use a twisted pair to reduce noise and crosstalk. USB 3.0 cables contain twice as many wires as USB 2.x to support SuperSpeed data transmission, and are thus larger in diameter.[44]
The USB 1.1 Standard specifies that a standard cable can have a maximum length of 3 meters with devices operating at Low Speed (1.5 Mbit/s), and a maximum length of 5 meters with devices operating at Full Speed (12 Mbit/s).[citation needed]
USB 2.0 provides for a maximum cable length of 5 meters for devices running at Hi Speed (480 Mbit/s). The primary reason for this limit is the maximum allowed round-trip delay of about 1.5 μs. If USB host commands are unanswered by the USB device within the allowed time, the host considers the command lost. When adding USB device response time, delays from the maximum number of hubs added to the delays from connecting cables, the maximum acceptable delay per cable amounts to 26 ns.[45] The USB 2.0 specification requires cable delay to be less than 5.2 ns per meter (192,000 km/s, which is close to the maximum achievable transmission speed for standard copper wire).
The USB 3.0 standard does not directly specify a maximum cable length, requiring only that all cables meet an electrical specification: for copper cabling with AWG 26 wires the maximum practical length is 3 meters (9.8 ft).[46]
8 metri sono un po' tantini per l'USB a meno di utilizzarli per un mouse o tastiera.
Se la banda passante deve essere necessariamente quella nominale,ti consiglio dei semplici convertitori autoalimentati USB-ethernet per cavo Cat5
giuseppegerax
Innanzitutto ragazzi vi ringrazio per la vostra professionalità e per la vostra gentilezza. Il dispositivo che dovrei interfacciare sarebbe una telecamera per il cavo orale, quindi credo che un convertitore cat5 usb 1.1 non vada bene, o sbaglio?
Probabilmente il problema principale e' la caduta di tensione di alimentazione a 5 volts, fornita dalla Usb.
Il modello di convertitore mostrato per ultimo consente anche l'alimentazione a 5 volts locale, con l'apposito jack posto sul lato Usb femmina (visibile in foto)
