Fulvio Persano Inserito: 24 ottobre 2010 Segnala Share Inserito: 24 ottobre 2010 (modificato) Ciao.http://www.4shared.com/file/141999620/800f...ee_machine.htmlhttp://www.4shared.com/file/141999619/d2fe...ee_machine.htmlhttp://www.4shared.com/file/141999618/a5f9...ee_machine.htmlhttp://www.4shared.com/file/141999623/1906...ee_machine.htmlhttp://www.4shared.com/file/141999622/6e01...ee_machine.htmlhttp://www.4shared.com/file/141999621/f708...ee_machine.htmlhttp://www.4shared.com/file/141999629/f9d3...ee_machine.htmlhttp://www.4shared.com/file/141999626/696c...ee_machine.htmlhttp://www.4shared.com/file/141999624/8762...ee_machine.htmlhttp://www.4shared.com/file/141999635/e97e...ee_machine.htmlhttp://www.4shared.com/file/141999634/9e79...ee_machine.htmlhttp://www.4shared.com/file/141999631/ee13...ee_machine.htmlhttp://www.4shared.com/file/141999646/3f36...ee_machine.htmlhttp://www.4shared.com/file/141999641/a152...ee_machine.htmlhttp://www.4shared.com/file/142005215/8d60...ee_machine.htmlhttp://www.4shared.com/file/142005231/b83b...ee_machine.htmlhttp://www.4shared.com/file/142005242/6e73...ee_machine.htmlhttp://www.4shared.com/file/142005267/2c2f...ee_machine.htmlhttp://www.4shared.com/file/142005291/42d4...ee_machine.htmlhttp://www.4shared.com/file/142005298/3b08...ee_machine.htmlhttp://www.4shared.com/file/142005313/65c1...ee_machine.htmlhttp://www.4shared.com/file/142005319/8514...ee_machine.htmlhttp://www.4shared.com/file/142005331/b9f9...ee_machine.htmlhttp://www.4shared.com/file/142005337/509a...ee_machine.htmlhttp://www.4shared.com/file/142005368/bd52...ee_machine.htmlhttp://www.4shared.com/file/142005370/aa92...ee_machine.htmlhttp://www.4shared.com/file/142005378/a449...ee_machine.htmlhttp://www.4shared.com/file/142005393/ad18...ee_machine.htmlhttp://www.4shared.com/file/142008804/1c81...ee_machine.htmlhttp://www.4shared.com/file/142008803/82e5...ee_machine.htmlhttp://www.4shared.com/file/142008802/f5e2...ee_machine.htmlhttp://www.4shared.com/file/142008806/f28f...ee_machine.htmlhttp://www.4shared.com/file/142008805/6b86...ee_machine.htmlhttp://www.4shared.com/file/142008801/6ceb...ee_machine.htmlhttp://www.4shared.com/file/142008808/1537...ee_machine.htmlhttp://www.4shared.com/file/142008816/eb94...ee_machine.htmlhttp://www.4shared.com/file/142008815/729d...ee_machine.htmlhttp://www.4shared.com/file/142008814/59a2...ee_machine.html Modificato: 24 ottobre 2010 da Fulvio Persano Link al commento Condividi su altri siti More sharing options...
Ema78 Inserita: 12 maggio 2011 Segnala Share Inserita: 12 maggio 2011 Fulvio, ho visto che hai inserito una quantità notevole di schemi di montaggio, il che può risultarmi utile. Ma a me servirebbero gli schemi elettrici veri e propri, in quanto ho smantellato la mia Saeco Superautomatica degli anni 90 perchè pensavo fosse ormai fuori uso...poi ho pulito tutte le incrostazioni dai tubicini, verificato la funzionalità di ogni pezzo elettrico e con mia sorpresa ho notato che funzionavano tutti!Volevo quindi rimontarla e vedere che succedeva..ma ahimè...nello scollegare la marea di fili, pensando che tanto la macchina era da buttare e che, al limite, avrei recuperato qualche pezzo quà e là, non mi sono segnato i collegamenti.Anche se sono un'elettricista, non riesco minimamente ad andare a tentativi...troppi collegamenti...e poi c'è quel sequenziatore che rimane un mistero...Per caso riesci a sapere dovere reperire questi benedetti schemi?grazie.ema78. Link al commento Condividi su altri siti More sharing options...
Fulvio Persano Inserita: 14 maggio 2011 Autore Segnala Share Inserita: 14 maggio 2011 Ciao.Purtroppo, almeno per il momento, no.Mi dispiace, tutto quello che avevo trovato l'ho pubblicato. Link al commento Condividi su altri siti More sharing options...
beppe18 Inserita: 16 maggio 2011 Segnala Share Inserita: 16 maggio 2011 Ciao che macchina hai da riparare???che problema ti da ????prova a spiegarmi meglio ciao a presto Link al commento Condividi su altri siti More sharing options...
Ema78 Inserita: 31 maggio 2011 Segnala Share Inserita: 31 maggio 2011 ciao...è una superautomatica anni 90 credo...l'ho smontata tutta e i singoli componenti elettricamente funzionano tutti...l'avevo smontata perchè appena la collegavo alla rete elettrica e accendevo la macchina mi scattava l'interruttore per cortocircuito...così ho pensato che ci fossero dei danni seri e che fosse il caso di smontarla per recuperare ciò che di buono fosse rimasto.Pensando appunto che fosse comunque irreparabile ho scollegato tutti i cablaggi senza annotarmeli (mi sembrava superfluo)...e ho iniziato a testare i singoli componenti (motorini vari, f.c.,pompe, e.v.,ecc...) e, con mio grande stupore, ho notato che tutti funzionavano alla perfezione. Probabilmente il cto-cto era dato da qualche collegamento errato fatto da qualcuno che ci aveva messo le mani prima di me in azienda anni prima...infatti io la macchina l'ho trovata in un angolo e prima di fare posto ho provato a vedere se era appunto da buttare.Insomma, per concludere, a me servirebbero 2solo" gli schemi elettrici completi o, in alternativa, in modo di funzionamento passo-passo della macchina; per cercare di riscostruire lo schema di cablaggio...La vedo dura comunque perchè c'è una scheda elettronica nel blocco dell'interruttore ON/OFF, spie e selettore; ed inoltre che un dispositivo, tipo un sequenziatore, di cui ignoro totalmente la funzione.Questo è quanto.Ciao. Link al commento Condividi su altri siti More sharing options...
Riccardo Ottaviucci Inserita: 31 maggio 2011 Segnala Share Inserita: 31 maggio 2011 dovresti conoscere qualcuno del CAT Saeco più vicino che ti fotocopierebbe in via confidenziale il Service Manual specifico,altrimenti la vedo dura.Fino a qualche anno fa potevo interessarmi io stesso in quanto settimanalmente andavo presso questo centro del mio capoluogo di regione,ma ora ho perso tutti i contatti con quella persona. Link al commento Condividi su altri siti More sharing options...
Ema78 Inserita: 31 maggio 2011 Segnala Share Inserita: 31 maggio 2011 No..purtroppo non ho nessun aggancio o conoscenza...vedrò di scervellarmi per capire, piano piano, come possa funzionare il sistema nel suo insieme. Non sarà facile, mal che vada utilizzerò il macinino per vedere come viene il caffè e il sistema pompa-caldaia se avrò voglia di farmi un tè! saluti. Link al commento Condividi su altri siti More sharing options...
Sergio Tesio Inserita: 19 aprile 2020 Segnala Share Inserita: 19 aprile 2020 (modificato) Buona sera. Qualcuno saprebbe dirmi come potrei procurarmi lo schema del circuito elettrico della mia SAECO MAGIC CAPPUCCINO? Molte grazie. Cordiali saluti. Setgio Modificato: 19 aprile 2020 da Maurizio Colombi Unificata la formattazione del testo. Link al commento Condividi su altri siti More sharing options...
Maurizio Colombi Inserita: 19 aprile 2020 Segnala Share Inserita: 19 aprile 2020 Mi dispiace, ma il regolamento di PLCForum che avresti dovuto leggere all'atto dell'iscrizione, vieta espressamente di accodarsi alle discussioni. Specialmente a quelle ferme da parecchio tempo! Per favore riproponi il tuo quesito aprendo una nuova discussione. DISCUSSIONE CHIUSA Link al commento Condividi su altri siti More sharing options...
